Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Hello leah_mcmunn - the error code E-20 indicates that the water doesn't drain. This could be caused by either the drain hose is kinked or your household drain is clogged. If the drain pump is making a humming noise, check the restriction in the drain line. If not, then you might need to contact a professional to possibly replace the pump.
