Casio FX-260 Calculator Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change from having the answers displayed in scientific notation to normal number display?
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Jul 05, 2011
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675091
Points
21596
You can set your display mode to FIX or NORMAL ( 1 or 2) if you have them. However if the result is too small ( less then 0.001) or too large the calculator will use the scientific format. Generally if there are not enough display positions to show your result, the calculator uses scientific notation.
Answers look weird
Your calculator is configured to display results in Scientific notation
8*5=40=4.*10^(01). Exit scientific mode by resetting the calculator or changing the display mode to fixed or normal.
1helpful
Scientific notation
All calculator use scientific notation if the result is too small or too large. Some, like the Casio FX9750G II, offer you two Normal displays, Norm1 and Norm2 that have different limits when numbers are converted to scientific notations.
Here is how to set one or the other.
In Run>Mat press SHIFT MODE (Setup). Scroll down or up to reach the display line. Press F3 to select Norm1 or Norm2.
1helpful
I want to remove the word fix from the top of the calculator
You've got the display set to fixed decimal notation. To change it, press SHIFT MODE 7 to switch to a scientific notation or SHIFT MODE 8 and then 1 or 2 to switch to one of the norm display modes.
norm1 switches to scientific notation if the magnitude of the number is less than 0.01 .
norm2 switches to scientific notation if the magnitude of the number is less than 0.000000001 .
1helpful
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
5helpful
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
2helpful
How to change or put math mode without fractions or scientific notation on calculator fx-155 es natural display
I am not sure what you want because the mathIO mode IS THE ONE THAT DISPLAYS results as fractions.
You have two display modes: MthIO (with fractions, radicals) and LineIO (with decimals). Which one do you want?
To set MthIO press [Shift][MODE][1:MthIO]
To set LineIO, press [SHIFT][MODE][2:LineIO]
Concerning the scientific display mode.
Decimal numbers can be displayed in various formats, Fixed,Scientific, and Normal. If you do not want scientific display of results, just set the mode to Fix(ed) and specify the number of decimal digits. However if a number to be displayed (a result) is too small or too large IT WILL BE DISPLAYED in scientific format regardless of the mode you selected.
3helpful
Scientific notation when not wanted.
Unfortunately, you don't. For numbers whose magnitudes differ too greatly from 1, the calculator automatically switches to scientific (or engineering) notation. You can press MODE and change the display settings, but there is no setting that will force the calculator to show this number without an exponent.
2helpful
My TI-86 answers every problem with an E answer. example: 3*3=9E0 How do I make it stop doing this? This has always been a great calc till it started doing this.
It is still a great calculator and what it is doing now is not the result of a defect. Rather, it is a configuration setting that someone has activated.
The calculator has three display modes for the numbers.
Standard 'normal', scientific and engineering. The calculator respects the user's choice as long as possible, but if the numbers are too small or two large it uses the scientific display format.
To set the 'normal' display format:
  1. Press [2nd][MODE]. On first line of screen that is displayed, make sure that Normal is highlighted. If it si not, use the arrow to move cursor on it and press [ENTER].
  2. Use arrow to move cursor to 2nd line. Highlight the number of decimal digits you want (0, 1, 2, ...,or 9) and press ENTER.
  3. Quit the MODE setting. From now on the calculator will use the 'normal' display format with the number of decimal digits you chose, until you change this setting again.
  4. However if the number displayed is too small or too large it will be display it in scientific exponential notation. Subsequent numbers that are not too small nor too large will obey the 'normal' format.
Hope it helps.
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
E3 is displayed after an incorrect answer on TI84
ok there is not a problem. the "E" is the calculators way of scientific notation. So if u were to see 1.70 e3 it would really mean 1.70 x 10^3 which is 1700. If these are small numbers and you are getting these "e" ur calculator is in scientific notation mode. Press "mode" then at the top highlight the word "normal" and hit enter. You will be back in normal calculator mode.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
