GN Netcom GN 2000 Headset Logo
Posted on Jul 04, 2011
Plug them in and the sound continues through the laptop speakers. My laptop says the device is working, and the driver is current and operating. Wouldn't work on my PC yesterday, but now they do, but still won't work on my HP laptop.
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Jul 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
3067
Points
33
Under sound devices, make sure to select the headphone port as the designated output
Samsung gt s3600i
Got tot the lower right of the computer screen and open the Sound Icon by right clicking with your mouse over the ICON. Check the speaker setting there and look for the slider bar to see if the sound volume was near the top and/or if the speakers show up as being active in the system. If all seems correct, you may have to go to the Samsun web site, seek support/drivers and update the current sound drivers to get reset and operational. THE OTHER method is to go to your system DEVICES and run down the list to Sound. Open that and check all lines individually for Driver Update. The computer will seek an update of drivers from there also, and automatically do the work for you.
Syba USB2.0 7.1CH Sound Adapter will not work
which laptop you use? model number with operating system? 32bit or 64bit?
2answers
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
2helpful
I have upgradded my Laptop operating system to
Use the ones for Windows Vista. Vista Drivers work for 7.
Now considering these speakers plug in via headphone jack you dont need drivers for your speakers. You should be looking for sound drivers for your laptop.
Plug in headphones see if they work if they do then there is no reason why your speakers should not.
2helpful
2answers
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
2helpful
2answers
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
2answers
Sound not working on laptop
Hi there, Depending on operating system but assuming windows.
Start with going to your settings
open your Start menu, Settings, Control panel, Sound and audio devices, If everything checks out then proceed to
Start menu Settings, Control panel, System, Device manager, Hardware, Find your sound card, right click and select update driver. I hope this helps and good luck.
1helpful
Head phone not working
Start Control Panel
Look in Sound Devices
Check what default device is set, change it from the sound card to the headphone
2answers
Webcam
No,unless you want to upgrade your current soundcard i suggest continuing using your current one ..
Your problem is driver related,try installing your sound card drivers again .. if that doesn`t help you could uninstall your webcam drivers,it`s a software related problem so there`s no need for you to buy a new soundcard
Sound does not work with devices.
Dear SweetDreamz,
Its the sound card driver related problem, my suggestion is please re-install the proper driver for sound device. Or please let me know the operating system ,so that i can try to provide you proper driver for Sound.
Cheerup And Be Happy Always
Top GN Netcom Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
