Dishwashers Logo
Question about Dishwashers
Water does not enter upper tier in my portable dishwasher
Posted by gcgrumpus014 on
Anonymous
  • 244 Answers
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Posted on Jul 04, 2011
How do I position the pump in a 3 tier water fountain?
sounds like the PVC pipe should attach to the pump to carry the water to the third tier. Do you have pictures?
Jun 04, 2018 • Dishwashers
How do I position the pump nozzle in a 3 tier water feature on my balcony?
Sounds like the PVC pipe should attach to the pump to carry the water up to the third tier, most likely through the center of the fountain. Do you have pictures?
WHERE is the float switch on a frigidaire dishwater model # fmb330rgso
I am not aware of any float switch in this model. If this a portable dishwasher and assuming the water inlet connection is open, it is likely the water inlet solenoid could be faulty. Check this site for location of parts.
2helpful
Water is not pumping into the washer
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
2helpful
I have a water-softener dispenser in my Danby 1899 W Portable diswasher. I do not know how to fill the dispenser and I cannot run the dishwasher until this is resolved. The user manual provides no...
I couldn't find it either for a long time:
1) Pull out the bottom rack as if you were putting dishes there
2) Look at the bottom of the dishwasher and there will be a white circle (near the upper left side) where you can add the water softener.
I didn't use any for a while and the dishwasher worked great so I'm not sure why you can't run it.
Portable dishwasher: Water does not enter even though the faucet is on.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
heatman101
2helpful
My portable dishwasher runs a complete cycle seemingly fine but with no water
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most
Do these 'portable' dishwashers 'heat' water prior to washing? i have customer complaining bout the dishes not coming clean..yet the water entering the dishwasher is cold, does not appear to heat water...
Most dishwashers require a minimum 120 degree inlet water temp. The heating element will boost this up during the main wash cycle to aprox 140. Do not hook a dishwasher up to inlet water temps above 150.
12helpful
3answers
Upper spray arm is not turning round even though water is coming through. We have checked the internal system for blockages and the machine is filling / draining as normal. When a full programme is run,...
I found the problem to be neither blockages of the upper arm or roof spray arm or the upper basket arm hitting the the back of the dishwasher. the problem was that the pump inlet where the food scraps are macerated was blocked with all manner of gunge including small chicken bones plastic and other detritus. Removal of the macerator housing under the upper filter housing using 2 different sizes of torx driver easily fixed the problem. Probably why the upper dish rack cleaning degraded overtime, Directly proportional to the amount of detritus blocking the intake screen behind the macerator.17a8801.jpgb9e8fa8.jpg789f2b8.jpgfb7a626.jpgator. See pics
Jul 13, 2008 • Dishwashers
Water not getting to the upper level, dishes not cleaned.
Penrod, sounds like a circulation problem. Two things to check first. make sure the upper spray arm is not clogged with debris or split. Second is to twist and remove the filter and clear out any debris where the water enters the circulation pump impeller. If something has jammed the impeller, you would have to remove the dishwasher, remove the tank, remove the circulation motor and clean out the impeller...Catriver...post back.
Top Dishwashers Experts
Marvin
Marvin
mark warfield
mark warfield
