Question about Frigidaire FAM157S1A Air Conditioner
Compressor never shuts off, even after the pressing the off button , also never shuts off in Energy saver mode we just have to unplug the machine.
Posted by lamsalmaps on
1 Related Answer
Dan Favata
  • 233 Answers
SOURCE: T-Stat issue?? or Compressor?
Yes, the termostat and the main board will control the operation of the compressor. it could be the problem
Posted on Jul 31, 2009
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
3helpful
2answers
How do I take a samsung refrigerator out of demo mode?
Press "Energy Saver" & "Freezer Power" buttons and hold for 3 seconds.
How do i turn off energy saver toshiba e studio 203d
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver butto
1helpful
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
9helpful
3answers
How to ready toner not recognized
Hello
Please switch off the machine, while holding down0+8 buttons switch the machine on.
When machine starts and displays [ad] input 695 and press the start button.
Input 0 and press interupt and energy saver.
Input 971 and make sure that value is 3, if it is not input 3 and then press interupt then energy saver buttons.
Switch off the machine, wait awhile then switch the machine on.
The problem should be sorted out,
Regards
2answers
Do not know how to use the energy saver feature
i have a problem for minolta di351 by code c009 pls help me
CLEANS ITSELF TOO FREQUENTLY- 2-3 TIMES EACH DAY
Try maxing out your power save timers. Here are the instructions. I suspect the machine is going into power save mode to quickly. Here is how you do that.
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
2helpful
How to turn off the cleaning page feature in Xerox Phaser 8500
Actually what is happening is your machine is going into the power save mode and staying there for a long time.
What happens then is you get a full warmup. When the machine warms up, it will turn on the compressor and drain the resivour because Xerox wants a "fresh": supply of ink in the print head.
Its excruciatingly expensive and wasteful.
Here is something that can help. I am not sure you can completely disable the energy save mode. Thanks Al Gore...
2helpful
My phaser 8560 won't say on, so it prints out the cleaner page and info pages daily after the very long warm up session. How can I keep it running so I don't burn through this very expensive ink.
Here you go.
To enable or disable the Power Saver (Energy Star) mode:
NOTE: The printer will only have the Power Saver menu selection if the printer was sold as an Energy Star machine.The Power Saver mode can only be enabled or disabled from the Control Panel.
  3. Press the [Up] or [Down] arrow button to select [Power Saver], and then press the [OK] button.
  4. Press the [OK] button until the required option is displayed; either 'On' or 'Off'.
  5. Press the [Down] arrow button to select [Exit], and then press the [OK] button to return to the main screen.
3helpful
Shutting off
I would try the same solution as the E1 error code, Not sure if it will work, but it seems to be the same issue
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Frigidaire FAM157S1A Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Steve Oakes
Steve Oakes
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
