Question about Sharp Viewcam VL-NZ100U Mini DV Digital Camcorder
SOURCE: Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Posted on Oct 25, 2009
Testimonial: "thank you for the answer. Bill"
SOURCE: I have a sharp digital viewcam vl-nz100 that I
Yes. You can transfer the data from the card of your camcorder to the PC using the supplied USB cable to connect the camcorder to the PC.
For detailed steps, please refer to the instructions given in the user manual. (pages 65-66)
If you do not have the manual, kindly download the online manual by clicking this link:
http://support.sharp.net.au/downloads/opmanuals/VLNZ100Eom.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Thanks for using FixYa.
Posted on Dec 10, 2010
