I am going to assume the touchpad doesn't work, since you didn't elaborate much in your description. If it isn't doing anything, you need to reinstall the drivers for the touchpad. If you have an external mouse laying around, use it to go to the acer site and redownload the touchpad software and follow the instructions to install it. The next time you boot your computer, it will work.
is their a button above the touchpad? if there is press it, you may have disabled it. if that doesn't work plug in a mouse and go to control panel once booted and verify that the touchpad isn't disabled in device manager.
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Check if you accidentally locked the touchpad through the keyboard. If it is not locked, try to boot to Safe Mode and check if it responds, if not, just try to reinstall the operating system. If it still doesn't work then it needs repair.
Just check for the key combination on your keyboard (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
From my experience this is a hardware fault with the touchpad. Luckily you can buy a faulty player on ebay and replace the touchpad - make sure the fault on the faulty one is not the same!
The player is is easy to take apart and the touchpad easy to replace.
