Samsung X15 Notebook Logo
Anonymous Posted on Jul 04, 2011
Operating system not found in mini loptop samsung because accident i ereased the boot in drive c... i can't boot it with usb
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Jul 04, 2011
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3072237
Points
30576
You will need a new Windows cd with a program to boot up the system again for the manufactures do not give you one when purchased.
  • 2 more comments
  • Anonymous Jul 08, 2011
    what do you mean cd? my loptop is no cd player... i have a windows cd and i copied it to usb,
    and tried to boot it but not worked..
  • Anonymous Jul 09, 2011
    what brand of laptop does not have a cd/dvd player in it? what is you make and model?
  • Anonymous Jul 10, 2011
    its small loptop... thanks for your help.... finaly my usb is now working...
    no problem...remember when asking for advice always include the manufacturers name and model number too
Ubuntu USB
Is your computer set up to read the USB drive in the boot sequence?
1helpful
I have Samsung Electronic NP355E5C-A01US win 8, operating system It can not recognize the dvd rom. what sould i do? I wanted to run win7 setup from usb flash drive but it didn't work. can not boo
I have the same issue but this is from the original O/S windows 7 recovery DVD that came with the system, I have the original DVD external DVD Rom Drive, it starts to read and just stops responding
No operating system found
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and reseat (reconnect). Check BIOS. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
1helpful
2answers
Pxe -e61: media test failure, check cable PXE -MF: Existing PXE Rom Operating System not found How do i resolve this error message? How should i resolve & trouble shoot?
Welcome to fixya.
-The first thing to check is your boot order in the BIOS.
-Unplug from power, remove battery wait a solid 5 minutes and try again.
-Go into the BIOS and choose the Default settings (press F9 to set defaults then F10 to save and exit).
-It sounds like it can't find a hard drive to boot from so it's looking for the Network to boot from.
-If you have an external CD/DVD drive try to boot your OS from that (after changing the boot order).If it did not work then there is a big chance that the problem is a failed hard drive.
2answers
When i turn it on it shows no operating system not found
boot record has been corrupted, or the hard drive is toast!....problem is that you have no cd/dvd rom so you cant insert a restore disk....if you wanted to test it yourself you would have to learn to boot from USB(flashdrive)....unless you have a external USB dvd that you can hook up to it to attemot to rebuild the boot record!
When booting the laptop it says PXE-E61: media
When you start your computer, the motherboard searches connected drives for the operating system. The search order is usually the optical (CD/DVD) drive first, possibly a USB drive next, then the hard drive. If none of these work, some systems are set to try booting the operating system over a network cable. What the cryptic message you're getting is telling you is that the system tried a network boot without success, and that maybe the trouble is a bad cable.
This all means that your hard drive isn't being detected, or that there's no longer an operating system on it. It's possible the connector from the hard drive to the motherboard has come loose, which can sometimes happen since laptops get moved around. The hard drive may have gone bad, or there may be a problem with the motherboard that is causing it not to find the hard drive. Or the hardware may all be fine, but something (a virus or other malware, for instance) has deleted files needed to load Windows.
When the computer first starts, you'll see a message about how to enter BIOS setup. The BIOS is the motherboard's built-in program, and through the setup pages you can see what devices it detects. This will let you know if the hard drive is being found. Some boards include diagnostic tests you can run on the hard drive if problems are found. You can also check the boot order; you may find that for some reason the boot order has been changed so that the network boot is being tried first. Strange things can happen to BIOS settings, often a sign that the backup battery for the memory where the settings are stored is getting weak.
If you have access to a Windows XP operating system CD, you can set the BIOS to boot from the CD drive and try using the Recovery Console feature. Information about this can be found at Microsoft's site.
Good luck getting your laptop back up and running quickly. Thanks for using Fixya!
Samsung x15 - Operating system not found.
sounds like an issue with your hard drive. you could try running chkdsk /r either by removing the drive and connecting it to another computer as an axternal drive using a usb hard drive adapter or using something like the hirens boot disc, going into mini xp and do the check there.
http://www.hirensbootcd.org/download/
3answers
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
6helpful
3answers
Dell mini inspiron 9 - operating system not found
On my Dell Insprion Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Installing windows xp on usb hard disk or usb drive
It will require a dos boot from the CD when installed. Then it depends on if the install CD recognizes it. If it does happen it should work.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
