Question about Lexicon IONIX U22 Audio Interface USB
I have Lexicon IONIX U22, Widos Vista 32 bit i instaled driver..everything looks ok..but its not ok...comunication with computr is many times interupted...off on off on..this silly sound when usb interface is on or off...i tried many times to reinstal driver, i tried different usb cables..i tried different operating system in my pc..nothing helped......i cant use ionix...i start to recrd something and sudenly usb makes sound that it finished comuication with pc..then strts again..what i the problem? should i throw away lexicon or computer?
Posted by moskimoski on
Fred Yearian
  • Lexicon Master
  • 5,603 Answers
Check the power adapter for the Lexicon. The USB may not be supplying enough without the adapter to run this.
Posted on Jul 04, 2011
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Apr 16, 2011 | Lexicon Omega Desktop Recording Studio
My laptop does not recognize it
Do you have the correct power supply? MANY try to use a replacement power adapter that puts out DC rather than AC and that will not work.
Feb 06, 2011 | Lexicon U22 Ionix U-22
Whats the polarity of lexicon ionix u22 audio adaptor? should i set plus or minus polarity on the adcd transformer/adaptor? thankx
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
Feb 04, 2011 | Lexicon U22 Ionix U-22
Lexicon alpha does not install with XP SP1a, error = "Cannot start device code (10)" Drivers from disk are installed, device is listed in device manager with a yellow exclamation point. Do i need...
You should be at SP2, but that MAY NOT be the problem. One thing to check is if you are supposed to have the device connected when you install the software... in SOME cases doing it with or without connection will affect the outcome. Also make sure ALL virus/spyware/popup blockers are disabled during install.
Before using this device, make sure that going to the control panel and looking at the "Sounds and Devices" shows that the Lexicon is the inout and output device for all the tabs within that window.
Dec 16, 2010 | Lexicon Alpha Personal Recording Studio
I have a new Casio CTK 810 and installed driver and smf converter but cannot make a connection with my laptop and desktop, both Vista 32 bit........
Yeah, had that problem too with Vista (I used a 64bit) but it should work in Vista (32 bit) with limitations and Windows 7 32 bit
for Vista
http://support.casio.com/information.php?rgn=5&cid=008&pid=114
for 7
http://support.casio.com/information.php?rgn=5&cid=008&pid=934
Sep 29, 2010 | Casio CTK810 61 Key Keyboard
My DVD-rw drive can't install the DVD programs
Make sure the disk is for version 2.5 if you are using Vista. You can download it from the web.
Feb 15, 2010 | Lexicon Alpha Personal Recording Studio
WDM Driver failed to install is the first of four
Make sure you verify that your computer meets the requirements for the Omega. I have one of these and it installed on an XP with no problem.
Maybe you have Vista instead of XP. OFTEN there are incompatibilities of Vista. If you have that or heaven forbod Windows 7, you may either need a different WDM or have to backstep to the XP operating system.
In short, VERIFY the requirements of teh Omega and its software with the OS and system you are trying to install it on.
A last thing to try is to install it while in "SAFE MODE".
Nov 13, 2009 | Lexicon Omega Desktop Recording Studio
Lexicon IONIX U22 Audio Interface USB Logo
312 people viewed this question
Top Lexicon Music Experts
Marvin
Marvin
Are you a Lexicon Music Expert? Answer questions, earn points and help others
