Question about Canon IXUS 960 IS Digital Camera
My camera wil not start, he does nothing at all, the battery is loaded. What can I do.
Posted by Hans Pennings on
  • Hans Pennings Jul 05, 2011
    Thanks, but I tried 2 battery's and nothinh happens.
    Hans
Nomad
    Sergeant:
  • 166 Answers
Before doing anything else be sure the battery is actually capable of holding a charge. Worn out batteries charge very quickly in the charger. A healthy battery will take several hours to charge.
When a "charged" worn out battery is put into the camera battery voltage drops instantly when the camera tries to start from it - nothing happens in this case.
Posted on Jul 04, 2011
  • Nomad
    Nomad Jul 05, 2011
    Assuming a healthy battery able to hold a charge - check the battery contacts for obstructions as well as the battery contacts in the camera.
    When both contact rows seem ok and the camera remains lifeless without a single movement or faint sound - most likely its an electronics issue on the printed circuit board of the camera. In this case someone with experience in opening this type of camera might discover a clue why the camera won't start.
I have a GC-XA2BU and the camera will not cut on? I have purchased a replacement battery but neither work.
As soon as you connect a camera to a computer, it will stop working, because the USB connection will be used to charge the battery.
If your computer is not correct wired on the USB port, or when you are using a hub, without an external power supply, the battery will not be charged. So you end up with an empty battery and a camera that does not respond.
Try charging the battery on an external charger and remove the USB cable, before switching on the camera. Also check if the USB connector on the camera is free. Avoiding the camera to "think" there is still a USB cable connected.
Feb 11, 2014 | Cameras
Program starts to load once camera has been plugged in and turned on then window pops up and say failed to initialize program
Just uninstall the software(driver) and reinstall it, probably this wil help you.
May 12, 2011 | Cameras
Lens error it wil not come out and camera wil not caome on. I cant even upload my pics on to the computer.
If you've recently dropped the camera you may have lens damage that will require professional repair. But if the lens is OK, your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. This cures the problem about 90% of the time, and I hope it works for you.
Sep 05, 2009 | Nikon Coolpix S210 Digital Camera
My camera don't switch on,when i turn it on you sometimes hear the lens starts to zoom but nothing else happen. We checked the batterys etc with my friends camera and its fine so i dont know.The last few...
Indien ek die fokken kamera wil wegstuur sal ek betaal,dink jy nou regtig ek sal jou oor die R100 betaal om vir my klomp kak te vertel oor die email en as ek hom nie regkry is jy fort met my geld.....kak man....!!
Jul 31, 2009 | Fujitsu Cameras
Nikon CoolPix P80 Transfer software does not activate.
I had a similar problem. I uploaded my Nikon transfer program with no problem, and first time had no problem loading photos. Second time the transfer prompter did not come up on the screen. My manual said something about having a fully charged battery. I tried re-charging my camera battery, and tried again. It worked! The program came up and my photos uploaded.
Jul 19, 2009 | Nikon COOLPIX P80 Digital Camera
1994 Nissan Pathfinder won't start, even jumping it.
I had a similar problem w/ my 94 Pathfinder. The problem was a cheap security system that was offered in that year model and the wiring between the ignition and the starter was run through this system. The dealership was able to by pass the security system and this fixed the problem. For years other mechanics told me it was the starter but I knew it was something else.
Jul 14, 2009 | 1994 Nissan Pathfinder
Camera won't start Kodak batteries installed
just take off the batteries from the cam and press the power button fr few seconds then reload the batteries back to the cam... everythin wil be rite
May 22, 2008 | Kodak EasyShare CX7430 Digital Camera
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Sep 20, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Canon IXUS 960 IS Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
