Question about Kenwood KR-V5580
Hi, My friend (who has a visual impairment) moved house recently, they own a Kenwood KR - V5570, I assisted with re setting up PC etc. I am now baffled with connecting her left and right speakers to this as there are many red and white outlets. The wires on the speakers have one white and one black and white coating; also they have no jack on them, only bare wire to push into connections. My issue is that I have tried many combinations to get sound though had no luck. Can you tell me where I need to put the what wire in what place please thanks.
Posted by pandosandos on
Anonymous
  • 8,546 Answers
If you keep guessing you may succeed in blowing something up.
The cables have RCA connectors or bare wires for a reason.
Get the manual out and read it.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V5570-Receivers-manual/id/479bh938/t/2/
Don't pay too much attention to the actual colors of speaker wire. Use the colors as reference. Each speaker has a plus and a minus. Connect them to corresponding plus and minus for their respective amplifier outputs.
Posted on Jul 04, 2011
1helpful
Knob broken on Kenwood KR V5570
If you are in the U.S. you can try pacparts.com. You didn't say which knob was broken, so I couldn't research it for you. You should be able to find it there for yourself though.
2answers
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Do not hear the second click on speaker relay on kenwood KR-V5570 why?
I will assume no audio is coming out of your speakers.
When the reeciver starts up It looks at the load (resistance) of the speakers attached to see if it is reasonable. If It appears there are no shorts in the speakers then the speaker relay will close (second click) and send signal to your speakers. If there is no second click then either the the reciver is detecting a problem with speakers or cables or the detecting circuit has failed. I would start by disconecting all speakers then start the receiver up. If your not getting a second click after about 4 or 5 seconds then the receiver will need service. If it does click then shut receiver off, and hook up one speaker at a time, then re-start receiver. If one speaker suddenly makes the system fail then you have found your problem. If you have a Volt/Ohm meter, set it to resistance(Ohms) and measure each speaker. Anything Under 4 ohms will be a problem.
Good Luck
1helpful
2answers
Same problem with KR-A46
Hi all,
may I ask if anybody solved the station memory problem
with Kenwood KR-A46. I do have the same and I dare to fix it
but I am looking for the right solution.
Thanks!
Ralf
4helpful
My Kenwood KR-V5570 receiver powers off when I try to run a medium to high volume and the standby light blinks
i had exact problem.
the bare wire speaker cables that connect via a clip connecor in back of the receiver are pushed too far in. something inside is shorting out with the speaker cables. solve this issue by either tightly twistng or soldering the wire ends ( then clip the ends about 1/4 inch long). watch out for the same issue of electrical shorts at the speaker end of the cables.
2answers
Hook-up
You should first check the ratings and specification. Then only you can hook up. But from my side plz always use compitable systems
Kenwood KR-V5580 Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
 Francisco Mauricio...
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
