Question about Rowenta Commercial Garment Steamer - White
How do i open d rowenta garment steamer to change the fuse or burnt wires
Posted by koldcase on
Allaisa
    New Friend:
There are four screws (Phillips) but you need long thin screw driver to remove them. Then there are TWO screws underneath the Castors. Just pop the Castors and turn them and you will see the screws. BTW there are two fuses inside. One you can replace and the other one is soldered in and you need to be little skilled to replace it. Chances are if the first one blew the second one should be OK. Good luck.
Posted on Sep 15, 2011
  • 1 more comment
  • sara Nov 14, 2011
    Is there anything else you do besides remove those 6 total screws? I have the same problem but still can't get the top off the dumb thing after removing the 4 main screws and then one under each castor wheel. I must be missing something?
  • sara Nov 14, 2011
    Sorry- I was just being a little too timid. Had to put a little more power to it. I just can't figure out where the fuse is you reference
  • sedge843 Jun 22, 2013
    Where are the fuses located inside the Rowenta IS7850 and any idea of the part number or where to get replacements?
Were can i take my rowenta steamer for repair in the 90035 los angeles area
Anaheim, Berkley, Fresno, Bakersfield, Los Angeles,
Long Beach, Sacramento, San Diego, San Jose and San Francisco.
Google Rowenta repair Center, choose a city and go!
Jul 24, 2014 | Rowenta Commercial Garment Steamer - White
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
Dec 26, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Jun 10, 2009 | Rowenta Commercial Garment Steamer - White
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - White Logo
1,140 people viewed this question
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
