Adjust the Green screen drive,turn it down and see if that corrects the problem.
Remove the Front Bottom Panel on front of Tv and behind it will be the Screen/Focus Control block
It will have 3 controls on Top for Focus to each Tube R/G/B
and under them are the Screen drive controls for R/G/B.
But if adjusting the Green Screen Drive Control does not Fiox It ,then you have a Bad Green Tube.
The adjustment inf seems right. However, there is no removable panel on the Front Bottom of this TV. Thus it is unclear where to make the adjustments mentioned.
Below the Front OF Your Screen is the bottom panel Cover and IT doses come OFF,their is 2 screws that hold it on,they are on bottom of panel behind 2 cover buttons,one on each side.
Thanks, I will give it a look. I did not notice the screws before.
Let me know when you get the Front Panel off and adjust the screen drive control ,while your their take a look at the CRT board that is connect to the Green Tube make sure it is OK and does not a any burt marks on it.
