Question about Maytag Neptune MDE5500AY Electric Dryer
Hi, These things have been happening for quiet some time and should have been addressed but weren't: Squeaking (loud), electronic panel doesn't work, sometimes the dryer doesn't work at all and sometimes it does. I've tried unplugging it and plugging it in again, it doesn't help. Can it be fixed and who should I call
Posted by trgottlieb on
Mike Cairns
  • Maytag Master
  • 3,053 Answers
Hello, trgottlieb I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Squeaking noise coming when car starts and turning right?
The fact that it happens when turning would lead me to believe that it is the power steering belt. Check your belts for tension, cracks, glazed and any other condition that would warrant replacement. If to much deflection when checking the belts at the longest stretch of belt adjust the belt.
Jan 20, 2013 | 1996 Jeep Cherokee Sport
HELLO, The Problem I'm having is My Honda EX 800 Generator, The Problem is, it's loud and also has a loud rattle, ANY IDEA'S ????
When it comes to gas generators "quiet" is a relative term, the EX 800 is quiet relative to other gas generators yes, but is not quiet by any means. If you hear a rattle check the panels for a loose sections which you should be able to hand tighten with a screwdriver from either end of the unit.
May 16, 2012 | Honda Electrical Supplies
Dryer makes a loud squeaking noise when i fill it with clothes and turn it on.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 05, 2011 | KitchenAid KEYS750LQ Electric Dryer
Dryer makes a loud squeaking noise while spinning
heatman101
Sep 02, 2011 | Whirlpool LEB6200 Electric Dryer
The ge profile dryer #dpsr473ew is malfunctioning. it makes a very loud squeaking noise when it is on
heatman101
Aug 31, 2011 | GE Profile DPSR473EW Dryer
Kenmore dryer he2 - loud continous squeaking noise
heatman101
Aug 20, 2011 | Dryers
LG Dryer is making a loud thumping and squeaking sound while drying clothes.
heatman101
Aug 13, 2011 | LG DLE2512W Electric Dryer
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
Hot Point electric dryer squeaking when in use.
It could be one of the pulleys on the bottom of the drum. Take the top and front panels off of the dryer. Get some WD-40. Now the hard part, there is no easy way, but put your right arm in underneath the drum (the right side of the drum)and spray the pulley the best you can. This is the hardest, but the easiest way to fix this problem, without having to take the entire dryer and drum apart. I had the similar problem. I didn't completely fix the problem, but the squeak has been significantly quieted.
Feb 14, 2009 | Hotpoint NWSR483EBWW Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
