I need the codes for a hatachi tv - Televison & Video
Posted by dgaf2316 on
    Top Expert:
  • Televison & ... Master
  • 76,455 Answers
Hello
Three digit universal remote codes for Hitachi are:
001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit universal remote codes for Hitachi are:
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Posted on Jul 03, 2011
Hatachi 42in tv L42vco4u blue light flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 17, 2015 | Televison & Video
HOW DO I CHANGE MY hITACHI TV LANGUAGE INTO ENGLISH
I want my hatachi tv c21-fl21m factory code plllzzzzzzzz
Sep 25, 2010 | Hitachi C21-FL21F 21" TV
I have a GE Universal remote but i cant find the code for my Hatachi ultravision. Where do i find the code
Which GE remote do you have (some use 3 digit codes and others use 4 digit codes)? Try here for a list: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Please note if the remote was programmed less than 6 months after your TV came on the market or is older than the TV, the codes for your TV are probably not included. There is a lag from release of a TV to the codes getting to a universal remote company.
I hope this helps.
Sep 22, 2010 | GE Televison & Video
TV Hatachi 50UX22BA turns off after about ten to 30 seconds after
No, Replace both of your STK ICs STK392-110s use 150s Mats has them 1-800-628-1118
May 11, 2010 | Televison & Video
What are the tv remote codes for hiatachi and lg??
it would be helpful if you specified what models you are referring to and do you want remote control hand unit programming codes or other .
Apr 20, 2010 | Hitachi 43FDX01B TV
I need a code for my hatachi tv since i had no luck with the search on the universal remote
just press code search and then TV then press power on while you in tv front till the tv turn on, then stop! you can use it now but don't removed the battery at a time!
Feb 14, 2010 | RCA Universal Remote Control
Remove base off my 37 inch hatachi tv we hung on the wall
there are 4-6 screws or bolts on back near middle bottom of tv usely marked with arrow or S
Nov 28, 2009 | Hitachi 37 in. LCD TV
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Re-programing remote
i need my code to my remote its a rcr311w to program it to my hatachi tv. and how to program it.
Nov 30, 2007 | RCA RCU410W Remote Control
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
