LG 42LC2D 42 in. LCD HDTV Logo
Posted on Jul 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv , wont turn on , i unplugged it to change my room around , and now it wont turn on
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jul 03, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368241
Points
33650
Can you turn it on using the power switch on the TV since this one is known to have bad contact switch at the IR remote input jack on the back of the TV.
LG:
1) Test the remote:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Post back what you find for further help.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Anonymous
Level 2:
New Friend:
  • Expert 106 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
106
Questions
Helped
26884
Points
272
Check the socket in next room , wherer as TV is required to be used with tester if the sockets r having the electricity. also if no tester is available. check the switch with any other applince i.e mobile charger etc if current is passing on. else you have to open the TV back lid with 4 nuts with a screw driver n switch the scrren n check with kavya stich with tester if its getting a current or not as well as the fuse besides it if a small line inside is intact or broken . in case its broken . get it replaced n the tv ll be workig , for further info issue.get the TV checked from the workshop as it can be checked n then the solution can be provided accordingly.
Magnavox tv , when turned on the volume goes to cero by itself and control wont work on it
Make sure the batteries in your remote are new. Unplug the TV power for about a minute. Plug TV power in. Turn TV on and try remote again. If no luck, make sure no other IR devices are in the room and turn off any lights and try again. If no luck, try a new remote. If no luck. your TV may need to be serviced.
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room
www.thestudentroom.co.uk > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Screen stays blue and wont show the picture
TV may be on the wrong input and that will give you a blue screen. When you turn the TV on and the screen starts lighting up it should show on the screen what input the tv is on. If it is not on correct input change input with the TV remote or buttons on the tv. If it is on the correct input try a power cycle on the cable box, just unplug the cable box power cord for a few seconds and then plug it back in. If neither of these solve the problem describe how the cable box is connected to the tv.
1helpful
Won't turn on after unplugging sansui
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Not turning on
you need to replace the flyback which is flyback 259296 and also capacitor CP150 and CP114. You can get replacement parts at the following link and they include free step by step instructions with pictures so you can easially repair the set yourself. Heres the link.
http://servicemanuals.vstore.ca/
Tv wont turn on
The power supply or high voltage circuits have failed, You will need to take it to a repair shop.
RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
