Hello [1] Turn on a desired device (e.g.,VCR or DVD player) and, if NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program [2] On the remote control,press a device key once (i.e., VCR/PVR, NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume,andVCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) [3] Press and hold SET until the LED (red light) blinks twice, [4]Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter [5] Aimthe remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works. If it still doesn't work, try
Codes for Toshiba TV with One for all URC 4220 are:
0060, 0154, 0156, 1265
applicable, insertmedia (e.g., cassette or disc).
before starting step 2.
DVD,CBL/SAT,or TV).
Combo, press CBL/SAT once.
then release SET.
the LED will blink twice.
the same code again
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
OK.
The instructions and codes for the One-for-All URC4220 can be downloaded by clicking on the following link:
http://www.oneforall.com/uploads/support/8210f6981b8d184d890a27645d6c32df.pdf
The codes for Toshiba TVs are 0060, 0154, 0156 and 1265. The complete code listing for all devices is at the end of the instructions. Please note, you will need to have Adobe Reader or another PDF file viewer installed on your PC to open the file:
http://get.adobe.com/reader/
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
