Question about Ricoh Aficio MP 161 Black and White Copier
I have copier it given me this code SC 544 & SC 542 & SC 500 can you assist me please .
Posted by naajmaa on
vincent
    New Friend:
  • 57 Answers
Overload of the main motor or fusing unit (SC 500)
Look at your fusing unit, (rollers, thermistor, lamp, gears...)
and don't forget to reset SC code in SP mode.
Good luck
Posted on Jul 05, 2011
Ricohmachine mp 5055 has sc code 554
The Ricoh copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Jul 03, 2018 | Office Equipment & Supplies
Pro c900. What does error code sc544 mean?
SC 544
Heating roller thermopile (center) error 3 The thermopile detected a temperature over 260?C. • TRIAC short, AC drive board defective • Defective IOB 2 • Defective BCU sc_note_1.gif
Related SC code: SC 553, SC563 1. Do SP5810 to cancel the SC fusing code. 2. Replace the AC drive board. 3. Replace the IOB 2. 4. Replace the BCU.
GO TO SERVICE MODE AND SP5810 to Clear - Check temp inputs - SP5803 150, 151, 152
Mar 13, 2016 | Ricoh Office Equipment & Supplies
I have LANIER LD115 Copier/ printer can not copy and print ,red light showen on copy button,Erro shown " SC: 544" AND " CALL SERIVCES" , GREEN Light on copy indicator, red on printer light, shown up
The copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
PSU board is bad
IOB board is bad
BICU board is bad
Defective thermistor in the fuser
Defective power supply
You need to contact a local service technician to take a look at your copier.
Nov 08, 2014 | Office Equipment & Supplies
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
When copier is putting on , it displays " error code SC:544"
that is a fuser overheat code. You can try pressing clear all, then enter 107 and hold the stop button until you see the SP mode come on the machine, then as it is in that mode, shut the machine off and back on.
If that doesnt work. I would suggest replacing the fuser unit.
You would need thermistors, rolls, overheat thermostadts.
Individually they would cost more than replacing the fuser.
Aug 12, 2010 | Ricoh Aficio 2015 Copier
Ricoh Aficio 1224c error code SC 544
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Functional Problem on our Ricoh 1018D
Enter SP mode - Clear (yellow) key, 1 0 7 and hold and press stop (orange) key for 3 seconds.
Enter SP 5-810 (SC code reset) and
select “1”. Then switch off and on the machine.
If error still there, probably you have one of the following faulty;
Fusing thermostat open,
Fusing thermistor open or defective,
Fusing lamp open or
Power supply board defective.
Please, first check fusing lamp and thermostat for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Aficio 1018D Copier
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio MP 161 Black and White Copier Logo
1,191 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
