Question about Sharp AR-275 Copier
My sharp phohtocopy showing call for service F2-04 after opening the cover when booting please help me with the code to fix it
Posted by ebenebe william on
amir hamza
  • Sharp Expert
  • 318 Answers
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Posted on Aug 18, 2011
How do i fix a sharp copier that is close but still indicating close cover
The sensor that tells the machine that the cover is open may be broken.
I'd recommend calling a certified Sharp service company and having them fix it, it should be a quick fix.
http://www.sharpusa.com/CustomerSupport/ServiceLocator.aspx
Copier Collin Houston TX Copier and Imaging Expert
Jan 09, 2015 | Sharp AR-M207 All-In-One Laser Printer
My Sharp Copier AR 5618 is showing error F2 -64, i have bought a new toner cartridge and installed it yet its still showing F2 -64, please a need a code to clear this problem.
If you don't have a user manual, you can download one in PDF form for your copier at the Sharp website. That may have a legend to explain what the error code means, and how to fix it.
Nov 11, 2013 | Office Equipment & Supplies
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp ar5516 error e7
with such error displayed press the print button, the machine shows another sub code, if it is 11 or 12 means a trouble with the scanner section.
to fix take out the glass ,clean the white strip left, the lamp reflector and mirrors, open the lens cover (5) screws, clean the lens and CCD.
if the subcode is 16 a trouble with laser
Nov 18, 2011 | Sharp Office Equipment & Supplies
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
I have a sharp 2025
Hello !
That error code indicates a drive problem with 4th/5th mirror assembly, motor, sensor, board. Your copier has a stepping motor failure and a sensor failure.
Needs to be serviced.
Hope this helps.
Oct 18, 2009 | Sharp Office Equipment & Supplies
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Aug 18, 2008 | Sharp AR-M207 All-In-One Laser Printer
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
Sharp AR-275 Copier Logo
411 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
