Hi my samsung remote is damaged.I have a one for all tv universal remote & have lost the instuctions to program the remote to the tv. I need the instructions program my one for all tv remote to my samsung 42inch flat screen plasma.
Posted by www_jumpd on
Electro Med Services
  • Televison & ... Master
  • 6,694 Answers
Hello
These are the programming proceedings for a one for all universal remote control.
[1] Turn on a desired device (e.g.,VCR or
DVD player) and, if applicable, insert
media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely
before proceeding.Highlight or write down the
codes and device you wish to program before
starting step 2.
[2] On the remote control,press a device key
once (i.e., TV,PVR,DVD, CBL/SAT,AUD,or VCR).
NOTE: To program control of a cable box or
satellite receiver, press CBL/SAT once.
NOTE: To program control of a CD player or
audio receiver, press AUD once.
NOTE: To program control of a TV/VCR Combo,
press VCR once.After programming, you will be
able to control channel selection, volume, and
VCR functions.
NOTE: To program control of a TV/DVD Player
Combo, press DVD once.After programming,
you will be able to control channel selection,
volume, and DVD functions.
[3] Press and hold SET until the LED (red light)
blinks twice, then release SET.
[4] Use the Manufacturer's Codes to locate the type of device and
brand name and then enter the first fourdigit
code for your device. If performed
correctly, the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps
2 through 4 and enter the same code again.
[5] Aim the remote control at the device and
press POWER once.The device should turn
off. If it does not, repeat steps 2 through 5,
trying each code for your brand until you
find one that works.
NOTE: If the device does not have a POWER
key, press the (Play) key.
[6] Repeat steps 1 through 5 for each device you want to control.
OK.
Posted on Jul 03, 2011
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
AEGG3CLL803606Z Samsung flat screen tv lost remote need codes to RCA Universal Remote
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 16, 2014 | RCA Universal Remote Control
I've one jumbo universal remote I lost my manual and just need the code to program my Samsung TV
Codes to check are: 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Nov 04, 2012 | Sentry Safe Sentry RMC10 Universal Jumbo...
Just moved and lost my samsung remote. I have direct tv but I'd like to watch movies. Will a universal remote fix my problem? Also, where is the model number on a samsung LCD tv.
The model number (label) is usually located either on the back of the TV, or on the r/hand side of the TV.
To obtain the best from your set, you ideally want the original factory remote. However, some Samsung remotes share the same functions.
Generally, the remotes are specific to each brand, but some brands of remotes have been known to transmit similar frequencies (i.e. Philips & Samsung).
You can only use a Universal remote, if the remote supports the Samsung programming codes (check the remote's user guide to see if Samsung codes are supported).
Cheers,
Sep 04, 2011 | Samsung Televison & Video
Lost book on remote need zenith codes for rca remote to program tv
Which RCA remote are you using? RCA Universal remote codes are available at the code finder: http://rcaaudiovideo.com/remotecodefinder/ . Enter the model and then the device in the two drop down menus then click Search.
For example the Zenith codes for the RCR312W are 11423, 10017, 10463, 11265, 10178, 10030, 11145, 10145, 10092, 10016 .
Please note that codes programmed in the remotes are usually limited to those for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
Jun 21, 2011 | Televison & Video
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
Program universal remote
I'm asking how to solve this...
Sep 25, 2008 | RCA RCR460 Remote Control
How do i program my Quantum Fx REM-600 universal remote?
Kjarrett,
The reason your universal remote won't control advanced functions is because it's not meant to. Universal remotes are intended to be a convenience and usually only control the basic funtions like channel, volume and mute. Sometimes a higher end will do some other things, but you will need to get an original remote for your brand and model of TV to do everything you want to do. Sorry I can't give you better news.
Hope this helps, and please rate my advice, good OR bad.
Dec 05, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
