If your dishwasher is connected to a garbage disposal and not used frequently and you
hand wash dishes on the disposal side, the soap that is used for hand washing dishes
accumulates in the dishwasher when you pull the stopper. This soap sudses excessively in
the dishwasher when it is run. This happens quite frequently in the apartments I service.
I have to put in several pans of water and turn the timer till it pumps out several times.
Also, make sure the disposal is working properly or the dishwasher will not drain and dish
water will back up into the dishwasher. There is usually a 5/16 allen socket to free
the disposal located under it in the very center of the disposal as well as a small red sqare
reset button once the unit is freed up. Make sure switch is off at wall before attempting
service.
hope this helps.
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump Check Pressure Switch Check CCU
ERROR CODES
DISPLAY EXPLANATION AND RECOMMENDED PROCEDURE
Suds
6 - 7
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the
excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
