User manual for jnc JAC-24Y2???- want to know what the optimal setting for heating temp is for economy in the unit. We seem to have to have ours set quite high to get the unit to run consistently. If we lower the temp it runs and heats but shuts off for periods of time...new house ...new aircon????
Posted by rseastcott on
okcarltons
    Champion:
  • 230 Answers
Normal settings 70 heating 74 to 76 cooling, I try to leave my cooling a 76 and keep it there. 76 degrees feels good if its 95 or hotter out side and the lower you set it the more it will cost.
Posted on Jul 03, 2011
Tub won't heat Message SL
Not much info here but SL could be the mode setting. Typically modes are SLEEP, ECONOMY and STANDARD. Standard maintains your set temp at all times even if it has to turn on outside of normal filtration cycle. Economy only heats during a filtration cycle, and sleep will only heat within 10 degrees of set temp and only in filtration cycle. This cycle is really only useful while going on vacation or other extended periods of non-use. Not sure how to help change modes without knowing what spa pack you have but you should be able to find the owners manual on line with a little research.
Mar 02, 2017 | Pool & Spa
Can I buy new remote for JNC split system JAC 24Y2
Fixya does not sell replacement remotes. There are vendors of replacement OEM remotes on the internet.
Jul 11, 2016 | Heating & Cooling
What does economy button mean? When it is not on economy it goes above the desired temperature setting but when it is on economy it never reaches the desired setting. Can you help??? Do others have th
According to the owners manual, the "Economy" mode is designed to reduce the temperature setting by 2 degrees every hour. May not be what you were expecting... On the too hot issue: Check the thermostat setting - it can read either Celsius or Farenheit - Make sure you are setting it to what you think you are... Recommendation: if it is heating higher than set temperature is 1) set the temp lower and see how it does or 2) call a repair man to check and calibrate the thermostat.
Jan 15, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai 1004F, no manual. Vent Contol Button is in open position, its winter, should vent be closed at all? Economy button, whats it for?
Not sure about Vent Control however the Economy button is like a night time set back. Over a 2 hour period it will decrease the temperature up to 6 degrees from set point. In morning, just take off economy and unit will come up to temp. Go to www.rinnai.us for on-line manual.
Nov 28, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Motor always on...never turns off anymore after water temp. is reached
may be in default setting for filter time if unit loss power temp and filter reset to a default mode usually 95 degrees and 6 hrs every 12 hrs most people forget to reset the filter time
Nov 01, 2009 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
Rinaai LP space heater will not shut off when set temp is reached
Test the thermistor by using an ice cube. Place the cube on the thermistor and see if the unit starts. Then using a warm towel, wrap the thermistor ans see if it stops. Watch the display to see if it is registering the changes in temp. I suspect a bad thermistor.
Jan 02, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Im trying to find the optimal settings for my two bbl carb
You will need a vacuum and Tach meter guage, when the highest vaccum/RPM reading is reached the air fuel is near perfect, make sure you start lean and slowly turn the mixture screws out ( or in depending on carb type) evenly, reset idle speed if ness, as it can increase allot. In order to meet emission tests and get better fuel economy I would lean each screw 1/4 turn from best vaccum/RPM setting. Also verify the ignition timing is correct before any adjustment is made and engine is at operating temp.
Jul 28, 2008 | 1984 Dodge Ramcharger
We had a Honeywell 5220D installed by a HVAC company in April. Now my AC runs fine during the day and at night about 10PM the inside fan continues to run the thermostat is not yet at temp and the outside...
make sure the temper differ in cool mode are set 40-90 this is also a programable feature of this t-stat , by the way it also has offsets in the heat mode you might want to check this as well and make sure they are set check all wire connections for tightness and placement, also check to see if the t-stat is set to change from heat to cool auto mode or manual set to manual
Jun 24, 2008 | Honeywell Heating & Cooling
Janitrol Heat Pump
Jenny,
Sounds to be a system freon leak. The unit and the stat talk to each other and if the temp is not reached and the unit shut down in a set amount of time it turns on the E-heat. Now there are other facts that could be involved, plugged filters, dirty coils inside and out, etc. Check your filters first to eliminate that problem.
Apr 11, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
