Question about Casio QV-R40 Digital Camera
Don't know how to set up my camera to take pictues
Posted by fredandpat12 on
aaronhoff342
    New Friend:
    Problem Solver:
  • 13 Answers
Turn the camera on with the button on top, then take off the lens cap and insert a memory card into the side. The pictures will save to the memory card and you can buy an adapter to connect the memory card to your computer to view and save the pictures.
Posted on Jul 03, 2011
Having problems with my N90s
when you place the film in the camera & close the door does the film advance ?
Jun 06, 2013 | Nikon N90S 35mm SLR Camera
Kodak m583 will not delete pictues when you use the trash can button
To the other so-called solutions: your "solutions" sucked.
Here's how to do it: Click the "settings" icon on the screen. You get there by clicking the sides of the silver square surrounding the "ok" button (if there are no icons on the screen then click the "disp" button). Then in settings arrow down to the option that says "safe mode" (near the bottom) and change it's value from "Yes" to "No". Then the "format" will become available (2nd option from the last). Format the internal memory. Tada! Clean slate.
May 29, 2012 | Kodak EasyShare M583 Digital Camera
My vx2100 plays back every time I record something. I don't know why but it's super annoying. I figured the search buttons on top are loose or broken but I don't know. Is there any way I could...
The VX2100 is quite a complicated camera and can be easily damaged during disassembly. I don't know of any setting that would cause this to happen but you can try resetting the camera functions pressing the rest button to see if this goes away. Otherwise the camera should be repaired by a qualified technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 04, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
My camera fell in the sand I don't know if the sand got stuck in it & I don't know if that is what is causing the problem with the lenses not opening
is it notifieing you that there is a lens eror? or does it just not turn on? This type of problem you won't be able to fix yourself, and don't try to either! You will need to contact Kodak and tell them there is a lens eror (don't give details that you shouldn't be giving), hopefully they will be willing to fix it for you or replace with refurb.
Aug 30, 2011 | Kodak EasyShare M1093 IS Digital Camera
Samsung S8000 Camera is not working. I don't know why.
Try to go to the camera settings of your phone and try some adjustments or try to update the soft your phones camera, but if it doesn't work maybe your cellphone camera has a hardware problem.
Jul 01, 2011 | Samsung Jet S8000 Cell Phone
Hi, I own the Canon PowershotA540, recently I discoverd that once I put the SD card in my computer to download the pictures it downloads them, but once I put the card back into my camera all the pictures...
This sounds like the program you are using to download the pics is set to erase them from the card when the download is complete. You need to dig into the program and adjust the settings. That's as much as I can tell you since I don't know what program you're using. Your camera is fine.
Jun 20, 2011 | Canon PowerShot A540 Digital Camera
I have only 13 pictues on my camera and it says internal memory is full
Hi, You'll need to buy an SD card as camera's come with a very small internal memory and need to have more memory added in order to take more then, in this case, 13 pictures.
Jun 19, 2011 | Kodak EasyShare M853 Digital Camera
Flash just doesn't work on Kodak Easyshare V1253. whether on automatic flash or flash set to on. Used to have problems with the lens not fully closing, don't know if that helps. All in all, i have...
When you were having that lens problem, did you perchance open the camera case to repair it? If so, please see this link, and afterwards verify that all outer case screws are present and firmly seated (but don't strip them).
May 30, 2011 | Kodak EASYSHARE V1253 Digital Camera
What does the E mean on the screen.I put a new film in at Xmas time and only took a few pictures when the E showed up and couldn't click the picture. took to camera shop replaced batteries and film ...
If you go to http://www.pentaximaging.com/support/manuals-and-literature/ you can find the manual for your camera. From my experience the E on a Pentax camera means the film isn't loaded properly. Hope this helps.
May 11, 2011 | Pentax Photography
Casio QV-R40 Digital Camera Logo
Top Casio Cameras Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
