Question about LG Heating & Cooling
Our window AC unit stopped suddenly. Completely dead. The outlet has power. It's a 220V unit. LG window AC LW2510ER Any advise what it could be? Does it shut down when it's 100F outside? Thanks for your help. Matt in St. Louis
Posted by mlroeleveld on
  • mlroeleveld Jul 03, 2011
    It's not a 220V issue. I actually just solved it. i opened the temp control unit on the AC. There was a lot of moisture in there. Dryed that with a paper towel and after that with a hair dryer. Now it's working again.
    It's very hot here in St. Louis and I am sure it has to do with that.
Mike Cairns
  • LG Master
  • 3,053 Answers
It appears that it has froze up. Because it is so warm there, that it most likely just over worked itself and, froze up. Once you let it defrost some, or use hair dryer some to speed process, it should work fine. I hope this helps. Thanks Mike from fixya
Posted on Jul 03, 2011
icemelts
    Novelist:
  • 246 Answers
No - the outside temperature will not shut the AC down.
You say the outlet has power? Does it have the needed 220 volts? Most of the time 220 volts is on one switch, (that operates both 110 volt legs of power at the same time). - but sometimes each leg is on a separate breaker and if "one leg" trips you will still have power at the outlet (110 volts) but you won't have the needed 220 volts. While this is not likely - it is possible - so I would want to test the outlet with a voltage tester and determine the voltage. You might try checking in your breaker box and seeing if another breaker (110volt) is tripped. The same thing applies if you are dealing with fuses instead of breakers - determine the voltage at the outlet - and if you don't have 220 and only have 110 then look for a blown fuse or as I said above - a breaker tripped.
If you do have 220 at the outlet and nothing is running - I would be looking for an inline fuse of some sort within in the unit. Many of the newer units have them and they are usually easy to spot and all you have to do is to unscrew the fuse holder and replace the blown fuse. Be sure to have the power off when handling fuses.
Note: Be aware that while breakers/fuses can trip and blow without a serious problem going on - they (blown fuses/tripped breakers) are usually a sign of something significantly wrong with the unit.
Good Luck!
  • icemelts
    icemelts Jul 03, 2011
    While I sincerely hope your problem 'has been solved,' I seriously doubt that a little moisture inside an electrical box/switch would shut your unit down - and if it did (somehow do that) I would look for a 'return' of your problem and in more serious nature.
    "Moisture" would/could create a 'shorted' condition (if bad enough) that would blow fuses and/or trip breakers (either within the AC itself or remote from it) - but - 'causing the compressor/fan motor to not run' is a highly unlikely event. As I said above - the condition you described would more than likely cause a 'blown fuse or tripped breaker,' and my guess would be that an inline fuse might of blown, which is what should of happened. All this being said - if it really was 'moisture' that caused the unit to shut down - then my question would be 'how?' What safety opened? What switch opened? Doesn't make sense to me. The fact that 'both' compressor and fan motor would not come on - strongly indicates a 'inline fuse' blown. For 'moisture' to cause that - "it would have to cause a interruption of power somehow.
    I would also suspect an 'overload' condition, i.e. compressor motor/fan motor going off on internal overload - then sitting there 'cooling off' (which allows the overload to reset) and thus 'coming back on' and making you think 'everything is ok' - when in actuality - it's not.
    Only thing about that is 'why would both compressor/fan motor go off at the same time?'
    In any event - one can always blame it on a "gremlin," of some sort, yes?
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
No power, no clock, no light. Dead
you cant do much about this.. the only thing you can do is check if the power is going to the magnetron unit or not.
but i wouldnt suggest you to experiment with the unit as it can cause short circuits.
you should rather go find a cheap electrician
Mar 17, 2014 | Microwave Ovens
My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
May 23, 2012 | Kenmore Heating & Cooling
I have a Frigidaire air conditioner. I've never had a problem with it,at all until a few minutes ago. It all of a sudden quit working. I pushed the reset button and tried to push power, but nothing....
First check the outlet the unit is plugged into. It may be dead, due to a circuit breaker being tripped. Also, the interior of the outlet may be damaged or has a loose wire.
If a circuit breaker was tripped, unplug the unit before resetting the circuit breaker. Then plug the unit back in and turn it ON. If the breaker trips again, there may be a short in the AC wiring or there is another electric appliance on that same circuit, that may be causing an overload, when the AC unit is ON.
Hope this helps you to start troubleshooting the problem. Thanks for choosing FixYa.
Aug 10, 2011 | Frigidaire Heating & Cooling
We had a power outage and now our Maytage Gemeni stove won't go back on. Can't test the outlet, of course, since it's that weird huge plug, but all the other electricity is fine. The oven is completely...
Hi!!
Check breaker box for a tripped Double Breaker, probably 30A, If breakers are OK, unplug unit from wall outlet and wait 15 min. to reset the control board, plug unit it back up and check Range. You can check for power at the outlet using a voltmeter set on the AC mode.
Keep me posted!!
Dec 04, 2010 | Maytag MER5550 Electric Kitchen Range
My airconditoner window AC suddenly stopped working.. I had checked the power supply also, with the remote also its not working..plz help
Not much you can do unless you can do. Did you checked the outlet. Was the AC unit powereed up so the remote would work
Aug 20, 2009 | Heating & Cooling
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Unit is dead....
The power supply is the first place to start.
Is there a transformer? Check to see that there is AC on the primary & secondary of the transformer.
If no AC on the secondary, then the transformer is bad. If AC ok on the secondary, then look for a bad rectifier diode/module and/or regulator module. There might also be fuses on the DC side of the power supply.
If the unit is completely dead, it's most likely a power supply issue.
- Jim
Feb 08, 2008 | Panasonic WV-CM1020 Television
Heating & Cooling Logo
331 people viewed this question
Top LG Heating & Cooling Experts
Steve F
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
