Question about Mitac Computers & Internet
How to get laptop to conect to wifi it is a mitac minote Ge 8375
Posted by johncena7237 on
2 Related Answers
Anonymous
SOURCE: Mitac Minote
Problem fixed. The screen surround came off easily to reveal the inverter circuit board. Having retrieved some useful data from "laptopscreensdirect" I made a simple resistor network across the output to the CCFL (lamp). It allowed me to measure the output using a multimeter, Looking for 200v rather than 20Kv. On switching on the lappy the meter flickered and then indicated 0v. I purchased a replacement inverter online from the above web-shop. Easily replaced, my screen was running within minutes.
Posted on Feb 04, 2008
Anonymous
  • 7 Answers
SOURCE: i need drivers for evesham 8375 laptop
you can download a program that gives you the drivers from the internet like
driverscanner
driver detective
driver genius pro
Posted on Jul 31, 2009
Where are the fuses on a time8375
Usually in the wall plug. Laptops very rarely have internal fuses- no space for them and the actual power supply is housed externally.
Nov 24, 2012 | Mitac Time Evesham 8375 Laptop Heatsink...
My Ematic 7 4g wifi ebook reader can't conect to
just go to network setting and turn ON WiFi first, then make a search for the availebel networks
Nov 14, 2012 | Computers & Internet
How do i swich on the wifi on my dell xps m1210
Hi
Go to Control panel
than Go to Network Conections
than Enable your Wirelss Local Area Conection
After that you will be able to use WIFI wherever a WIFI is enabled
thanks
Jan 04, 2011 | Dell XPS M1210 Notebook
No power
Reset the memory modules and any other cards that are accessable, like the WIFI and modem cards.
Power up your laptop, does it work normally?
If not, then try rhe following steps.
Does it work when the battery is removed and the AC adapter plugged in?
If so you may have a bad battery.
Try this, unplug the AC adapter and remove the battery for a few minutes, leave the battery out and connect the AC adapter, power on your system, does the laptop work normally?
Power down, and reinstall the battery, with the AC adapter still connected, power up your laptop, does it work normally?
If not, the battery may be defective.
If NONE of the steps work then *********** board needs to be replaced.
I hope this helped, good luck and have a nice day.
May 26, 2010 | Computers & Internet
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
May 16, 2010 | HP Compaq nc6220 Notebook
I need drivers for evesham 8375 laptop
driverscanner
driver detective
driver genius pro
Jul 17, 2009 | Computers & Internet
Will my laptop router conect with nintendo ds lite
Not if Wifi connection is turned off. You may need to get a new connection and be able to keep the old one for no price. I dont know how to create a new wireless "wifi" allowed net, so you may need to ask around for help.
Feb 18, 2009 | WiFlyer - Portable, shareable WiFi base...
Wifi
Yes you should be able to with a USB cable. Most later models have either an Ethernet or USB cable port available on the printer.
Jan 03, 2009 | Office Equipment & Supplies
Mitac Minote
Enter your bios settings, then find the power managemont, check to see if the system is set to conserve power, disable power savings and see if the problem persists.
Jan 01, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Mitac Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
matt
matt
Larry Ng
Larry Ng
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
