EA - Electronic Arts Command & Conquer 3: Tiberium Wars for Windows Logo
Posted on Jul 02, 2011
1305.Error reading from file....MoviesG.big How can i fix it?, should i delete it?... thnks
Anonymous
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Jul 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
8847
Points
66
This issue may occur if one of the following conditions are true:
  • There is a configuration issue with the CD-ROM drive.
  • The MDAC (Microsoft Data Access Components) is damaged or is not installed properly.
  • There is an issue with the CD-ROM media. For example, the program CD-ROM is damaged or dirty.
Solution:
  • Examine the CD-ROM or DVD Disc
  • Clean the Program CD-ROM or DVD
  • Test the CD-ROM or DVD in another Drive
  • Clean the Drive
  • Quit Unnecessary Software
  • Look for Known Issues with the Drive or Recording Software
  • Check for Drive Firmware Updates
  • Make Sure That You Are Using Protected Mode CD-ROM Drivers
  • Enable and Disable UDF Support
  • Reduce Drive Caching
  • Disable Auto-Insert Notification
  • Remove Duplicate Drives]
  • Restart Windows in Safe Mode
  • Clean Boot Your Computer
  • Install the MDAC Update
  • Check for Alternate Installation Locations
if problem persist contact game manufacturer.
Bought Punch Home & Landscape Design Premium at
The reason of the error 1305 is a bad download or a bad disk
Try to contact Punch TD or try to download your file again
If the problem persists, contact directly with Punch
http://support.encore.com/ the best resources for Punch Software solutions
Punch Software Community Forum
Punchhelpers Website
Learning Punch Software (R): Basic & Advanced Training
Learning Punch Software (R): Importing, Exporting and Printing
Punchhelpers at Faceboo
1helpful
Error 1305.error reasing from file c:\program
If it is a valid error, not a virus or whatever,
these programs have security ideosyncrasies
which demands all files stay in place and unchanged
or they will protest to the point of not working.
You cant just delete from a program what you dont like
being there anymore.
These error reports are horrible.
They are not user friendly.
With every error should be a valid solution.
Even if you need a gig of database for the error reports.
The solution is to force the gaming industry and
software developers to include layman type solutions to
all thir errors possible.
Error 1305. Error reading from file C:\Program
Follow the instruction as per link http://support.microsoft.com/kb/248263
I hope that this has been very helpful for you
Problem to install wireless drive on averatec 3700
when installing thedrive check for instructions carefully by reading information on the installation window and try again
2answers
Cannot finish install of Hallmark Cardshop Deluxe 2009
ERROR 1305 is an error code returned when the cdrom can't read the disk either because it is a bad disk or a problem with the cdrom drive, I would contact this site:
http://www.hallmarksoftware.com/support/support.aspx
it may solve your problem. call them on the phone, tell them the problem and they may be able to help you.
Error message 1305
Microsoft has error 1305 as an "error reading from file." Check out http://support.microsoft.com/kb/248263 And try there troubleshooting, it could be that the disc is scratched or dirty, the drive could be bad, or it may be incomp[atable with the current operating system. The above link is your best first attempt at solving the problem.
good luck, hope this helps.
1helpful
Cannot install command and conquer tiberium wars????
try delete it or reinstall. if you can try to download a patch. they are usually some fixes to corrupt files that have been reported for unlucky buyers that have a bad file. so i hope it will work because tiberium wars is a great game =)
1helpful
I cannot get Command & Conquer Tiberium Wars to install.
This is a general error which arises with corrupted files.First Make a "Checkdisk" test and make sure that your D drive is fine with out any bad sectors.If everything is fine,then probably that particular file is corrupted.Assuming you have reinstalled the game,the file may be corrupted in the dvd itself.Check if the game is working on othe systems.Also first copy the game contents to your hard drive and try installing the game from there. Install the game in a different directory [drive].
Top EA - Electronic Arts Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
