Question about Danco CORP A0089221 KITCHEN SPRAY HEAD AND HOSE ASSEMBLY
I purchased a Danco Universal Kitchen Sink Spray (10345) and Danco Universal Kitchen Spray Hose (10341) and installed them, but water is leaking from the Kitchen Sink Spray and flooding my cabinet. What's wrong?
Posted by lgrasso on
  • lgrasso Jul 03, 2011
    Actually, I found out that the Kitchen Sink Spray was missing a washer. Was supposed to include two with instructions and one washer and instructions were missing.
prindle231
    New Friend:
    Problem Solver:
  • 4 Answers
If teflon tape was used, most likely the base casting split as overtighting can occur.
Posted on Jul 03, 2011
  • prindle231 Jul 03, 2011
    Dratt those people how take things back for credit that have no credibility.
Need to replace rubber on Grohe Ladylux Plus Pull out spray handle. How to get spray handle apart.
I bought DANCO "universal faucet pull-out spray hose - fits all facuet brands" from Lowe's, which came with all kind of adapter and the hose quality seems to be better than overpriced Grohe spray hose replacement (Grohe part # 46092). The only problem is that you may have to prepare a large rubber washer in order to the handspray (Grohe part#46298) as I don't see this large washer in the package but it is very important to fit in place to prevent water leakage. - Michael
Jan 13, 2012 | Plumbing
Just purchased a Ladylux faucet for my kitchen sink and want to know if there is any way to strengthen the water pressure (water stream). It is too weak for kitchen use. Please advise at your soonest as...
Do you have good water pressure in rest of house if not you may have to put a pressure booster system in. if you do there may be a water saver washer in the end of the hose on the faucet,you can disconnect the hose and if there is a washer with small holes in it you can take that out(you may have to put some type of hose washer back in the hose so it dosen't leak).
Jun 13, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Hi, just bought a sink spray head, put it on and water is coming out the base of sprayer, what did I do wrong?
If it's from the fitting where the sprayer head is attached to the hose check to see if there is a rubber washer. If the leak is not from the lack of a washer or damaged washer. Uninstall and take back for a replacement. There is nothing wrong with what you did. It should not be leaking.
Apr 08, 2010 | Danco CORP A0089221 KITCHEN SPRAY HEAD AND...
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
I have a new hose for my Grohe Euro Plus to replace a leaking old one. I have disconnected it from the water supply but now the ends of the the old hose will not fit through part connected to the sink...
There are 2 sets of nuts and washers underneath the faucet that holds the faucet in place. loosen them and the water lines (after turning the water off) faucet lifts off from the top of the sink. Replacement the the same, just in reverse. BE SURE TO USE TEFLON TAPE OR PLUMBERS PUTTY ON THE WATER LINE THREADS TO PREVENT COSTLY LEAKS.
Jun 20, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Apr 21, 2009 | Kohler Model 10433: FortĀ® Single-control...
Danco CORP A0089221 KITCHEN SPRAY HEAD AND HOSE ASSEMBLY Logo
970 people viewed this question
Top Danco Home Experts
john h
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
