Expert
- Posted on Jul 30, 2011
Re: My radio receives the wx stations fine, it transmits...
Here is the list just scratching the surface.
- Bad antenna
- Bad coax cable ......grounding externally or internally with shield.
- Bad/poor ground for antenna..........door to body, painted parts when mounted elsewhere.
- Antenna installed incorrectly. Nylon grommet must insulate antenna from contact with mounting bracket. Coaxial connector must have contact with bracket for grounding.
tx and rx have nothing to do with each other except coax.
Are you sure you are txing audio out? Meter movement does not mean audio is present.
