1. First Open Settings. You can find this under your Apps, or by sliding your finger down from the top of the screen and clicking the gear-shaped icon in the top-right corner.
2. Next, tap Connections.
3. Then tap Bluetooth. You can see if your Bluetooth connection is turned on or off here.
4. Then tap Scan at the top-right corner of your screen.
5. Next, press and hold the power button on your headphones. In order to connect your Bluetooth headphones to your Android phone, you need to activate pairing mode on your headphones. Depending on what headphones you have, this will turn them on and automatically activate the headphones' Bluetooth. You might also have headphones that have a different "paring" button. Check the instructions that came with your headphones to find out more.
6. Finally, find your headphones and tap them. Your headphones might be listed with their model number, which might be a series of letters and numbers. However, you can find them next to the icon with headphones and other devices.
By the way, if you need some better TWS wireless earbuds recommendations, see: Best TWS Wireless Earbuds
Add it as a new bluetooth device in the bluetooth menu!
