Question about Frigidaire FRA065AT7 Wall/Window Air Conditioner
The digital Display has stopped working on the air conditioner and we have only had it for 6 to 8 weeks. The air is still working but the display is not nor the remote
Posted by katrice95 on
okcarltons
    Champion:
  • 230 Answers
Take it back.
Posted on Jul 02, 2011
HOW DO I FIX AN AIR CONDITIONER DISPLAYING E6?
Hi this link is a13 page error code manual for air conditioners, Hope this helps....
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Apr 03, 2016 | Heating & Cooling
What does "Eo" mean? It comes up on my digital display
Eo means the control board is not programmed. Has to be programmed to function.
Jan 12, 2013 | Amana PTH123B25AJ Heat Pump Air...
My Air Conditioner has stopped responding to the Remote. I have checked with my mobile phone camera & the 1 light still works on the remote. The Air Con manual button works but remote does not. Is this...
Try with this method which happened last week experience. Replace new batteries. And also remove dc wire to indoor unit display sensor. And after 3 minutes fix it again. And now start with remote. Mostly it will. If not, you have to replace receiving sensor in PCB or replace complete PCB. Please write back about the result. Thanks.
Jan 27, 2011 | Fujitsu Heating & Cooling
Window unit will not power up
You need to check for voltage to the display. Just knowing the plug is working doesn't tell you that the electronics are getting power. It is possible that the power cord is bad. Once you have tested the unit and the unit is actually getting power to the display, then it's probably the control board in this unit.
Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
My programmable "Carrier"
blown fuse on circuit board, or transformer dead, or hot (red) wire disconnected or broken somewhere in circuit.
Feb 16, 2009 | Carrier BCA101R Air Conditioner
Maytag portable air conditioner runs for 2-3 seconds then stops and shows code "E1" on the display
empty water & clean filter.. full water drain (which takes a few weeks to fill) will shut off the unit
Jun 08, 2008 | Maytag Heating & Cooling
My maytag m6x06f2a-f window AC wont stop beeping
We had the same problem and changed the setting to auto and the unit seems to be working properly now. Not sure if this solves the problem, but for the past 1/2 hour the unit has stopped jumping between 00 and the temp we set.
Jun 07, 2008 | Maytag M6X06F2A Air Conditioner
Frigidaire FRA065AT7 Wall/Window Air Conditioner Logo
171 people viewed this question
Top Frigidaire Heating & Cooling Experts
Mike
Harjeet s. bola
Harjeet s. bola
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
