Washing Machines Logo
Posted on Jul 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Candy go 482/2 80 does not comlete the was cycle, it starts ok then 30min LED, no spion LED and door LED stats to flash then all leds go out, Switch on, all three LEDs while taking in water , the xycle repeats until the machine is 3/4 full with water. then pump is switched on and all the water ius drained out. the whole thing stats again. Three LEDs (30Min, No-Spin and Door) switches on, taking water in repeated ON off cycle till the machine is 3/4 full. then again empty it.
Anonymous
Level 2:
New Friend:
  • Expert 122 Answers
  • Posted on Jul 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
122
Questions
0
Helped
11817
Points
185
Door switch or panel troubleshooting
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
1helpful
Grand o 282
Seems that you need to check if the door switch is faulty or there is fault or loose connection on the switch. Remove and check for the switch action, replace if faulty.
1helpful
Have a Hotpoint WF250 washing machine. Fitted new door lock switch, but door lock LED now constantly flashes & washing cycle does not start, even though water pump clicks!
TRY CHECKING YOUR MOTOR BRUSHES.IF THEY ARE OK IT IS PROBABLY THE PC BOARD LOCATED AT THE BOTTOM RIGHT OF THE MACHINE AS YOU LOOK FROM THE FRONT
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
26helpful
3answers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
1helpful
Dishwasher not emptying
No solution as yet, will most likely replace the dishwasher.
Top Washing Machines Experts
john h
