Whirlpool GU2400XTP Built-in Dishwasher Logo
Question about Whirlpool GU2400XTP Built-in Dishwasher
Top rack - glasses etc... not getting clean - bottom rack and utensils seem fine?
Posted by slawmedlaw on
Anonymous
  • 244 Answers
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Posted on Jul 03, 2011
2answers
GE Adora Dishwasher won't change zones.
I would check for a water flow blockage in the pipes.
Wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
3helpful
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
Always little crumbs in glasses on top rack
Cleaning screens is part of regular use of the dishwasher and how to should be included in the user guide. If you don't have one look for it on the internet by searching for user manual for your model number which can be usually found on the side of the door or frame where the door closes. Good luck.
Dishes, glasses on the top rack dont get cleaned. The bottom rack is fine. What may be the problem?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
1helpful
Fisher & pakel dd-603ss top drawer wont drain
Have you cleaned the drain filter ? If not, clean that ( it is beneath the rack where the utensil bin is normally positioned and accessible by lifting up the plastic door..If that is clogged up then your drain flow will be restricted. Also, check to make sure the drain line is not restricted ( pinced or clogged). .And yes , the drain is pumped out. If these tips do not get you going, please write back and let me know.. will help get your dw going ...
Regards
1helpful
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Top dishes not getting clean
OPEN THE DISH WASHER AND PULL OUT THE TOP RACK AND SPAY IT OUT WITH AN OUT SIDE WATER HOSE BECASE IT GET CLOG SOME TIME
Glass arent coming clean
make sure you are loading bottom rack right remember water has to get up through your bottom rack to rinse out your glasses.
Top Whirlpool Dishwashers Experts
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
