The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
