Gaggia Titanium Espresso Machine Logo
Question about Gaggia Titanium Espresso Machine
The descaling procedure did not finish, even after 4 liters of water. After interruption the machine does not finish rinsing. Whenever I start the machine the display gives 'rinsing' I have found no means for resetting
Posted by mjmantel on
Anonymous
    New Friend:
Trying resetting to factory settings
Posted on Nov 10, 2011
2answers
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
2helpful
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
4helpful
How to descale machine-is there a video showing how? I have the Saeco Magic Comfort + machine.
Hi
I put this next statement in so your machine will last longer.
Enter the menu by pressing the menu button. Scroll down until you reach "water hardness" and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to "Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
21helpful
2answers
How do you descale my Delonghi Magnifica?
10.3 DESCALING Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing (section 12 - point 5), it is time to descale the machine. NOTE: when the light switches on, the coffee maker can still be used to prepare coffee. Proceed as follows: • Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers. Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite. • place a container with a minimum capacity of 34 oz. under the cappuccino frother (Fig. 3); • turn the machine on by pressing the button (Fig. 4). • wait for the green and indicator lights to come on steady. • press and hold the button for at least 5 seconds (Fig.14). The decalcification warning light will illuminate (section 11 - point 8) to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee). • turn the steam knob half a turn counter-clockwise (Fig.5). The descaling solution will come out of the cappuccino frother and start to fill the container underneath. • the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker. Fig.32 The two red buttons have snapped out CORRECTLY The two red buttons have not snapped out CORRECT INCORRECT 17 OPERATING INSTRUCTIONS • after around 30 minutes, when the light comes on (section 12 - point 1), turn the steam knob half a turn clockwise (Fig.6) until it stops. The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows: • remove the water tank, rinse it and fill it with clean water. • reposition the tank. • empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother. • turn the steam knob half a turn counter-clockwise (Fig. 5). Hot water will come out of the milk frother and fill the container underneath. • when the tank is empty, the l ight goes off and the light comes on (section 12 - point 1). • turn the steam knob all the way clockwise (Fig. 6) and fill the water tank with clean water again. • the program of descaling is now terminated and the machine is ready to make coffee again. NOTE: if the descaling procedure is interrupted before completion, the alarm (section 12 - point 5) is not deactivated and the procedure must be started again form the beginning.
2helpful
Cant remember how to de scale
Instructions per De'Longhi:
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing, it is time to descale the machine.
Proceed as follows:
cappuccino frother;
• turn the machine on by pressing the button.
• press and hold the button for at least 5 seconds. The decalcification warning light will illuminate to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn counter-clockwise. The
• after around 30 minutes, when the light comes on, turn the steam knob half a turn clockwise until it stops.
• turn the steam knob half a turn counter-clockwise. Hot water will come out of the milk frother and fill the container underneath.
• when the tank is empty, the indicator light goes off and another light (looks like a pitcher pouring water) comes on.
• turn the steam knob all the way clockwise and fill the water
NOTE: if the descaling procedure is interrupted before completion, the alarm is not deactivated and the procedure
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE WARRANTY.
You can download the entire pdf manual from the De'Longhi website: http://www.delonghiusa.com/index.php?texts&pid=10&catid=1
Helpful tips:
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water or use abrasive cleaning products/scouring materials on any part of your espresso machine.
5helpful
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
3helpful
2answers
I need to decalcify my delonghi 4500
Descaling is another word for decalcification - I would consult the user manual for your exact model, because these directions are actually for the EAM3400, so there might be minor variations:
When the appliance displays the message:
DESCALE
You should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE NO
• Press and the appliance displays the message:
DESCALE YES
• Press the button to start the descale program.
• Empty the tank and pour in the contents of one bottle (4.2 fl. oz.) of DURGOL descaler plus 34 oz. of
service centers.
and glaze.
• Place a plastic or glass container with a minimum capacity of 50 oz under the hot water spout (Fig. 3);
• Turn the steam knob half a turn counterclockwise (fig.3). The descaling solution will run out of the cappuccino
• The descale program automatically performs a series of run offs and pauses to remove lime scale deposits
• After about 30 minutes, the appliance displays:
DESCALING COMPLETED TURN KNOB
• Turn the steam knob a half turn clockwise as far as it will go (fig. 4).
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• Remove the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the collection container (under the cappuccino frother) full of liquid and then put it back under the
cappuccino frother.
• Turn the steam knob a half turn counterclockwise (fig. 3).
18
Hot water is run off from the cappuccino frother into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETED TURN KNOB
• Turn the steam knob clockwise as far as it will go (fig. 4) and refill the water tank with clean water.
• The descale program is now complete and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the program must be started again from the beginning.
3answers
Machine won't stop descaling cycle
MAKE SURE YOU DO NOT SHUT DOWN YOUR ESPRESSO MACHINE WHILE IN THIS MODE OR IT WILL INTERRUPT THE CYCLE. BE SURE TO CAREFULLY UNDERSTAND WHAT THE MACHINE IS ASKING FOR AND USING THE MANUAL MAY HELP YOU WITH THIS PROBLEM. WE HAVE NOT SEEN ANY OF THE PROBLEM YOU ARE SUGGESTING, BUT THERE IS ALWAYS A FIRST. IF YOU NEED SUPPORT AND YOUR MACHINE IS LESS THAN 1 YEAR OLD CONTACT SAECO AT 800-933-7876.
IF YOUR PRIMEA IS OLDER THAN ONE YEAR YOU CAN CONTACT CERINI COFFEE @ 718-584-6120 OR VISIT OUR WEBSITE AT WWW.CERINICOFFEE.COM
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Top Gaggia Coffee Makers & Espresso Machines Experts
mark warfield
mark warfield
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
