Quite often the window units need to be tilted slightly toward outside to allow drainage to run outside the window. Try pulling bottom inward slightly so rear is tilted downward at outside and see if that doesn't cure it. You should soon see dripping outside at back of unit where it should be. Make sure you check for small hole under back end and check that it is clean and open.
