SOURCE: my laptop tushiba satellite p25 s670 doesn
you might have bad memory.if you have more than one dimm installed try using one at a time.
Good luck
SOURCE: power on but no screen oor hard disk motion
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
SOURCE: My toshiba satellite p25 s670 suddenly stops
boot it to safe mode, then run a system restore a week before the issue
occured. if there is any resource in conflict with what was installed,
this will be removed and problem resolved.
if that did not help, open the laptop up and remove the memory and hard drive, then re seat them properly.
SOURCE: toshiba a135-s2356 laptop no bios screen on power up
There are 2 ways you can reset your bios.
1.
On the motherboard there is
a small watch battery. Remove this battery along with the power cable
from the power supply. Hold down the power button to fully discharge the
system. Wait 2-3 minutes then reinstall the battery
and plug in
your system. Your reset is now complete
2. Some motherboards have a 3
pin jumper by the battery. Lets say that the jumper is on pins 2 and 3.
Remove the jumper while the machine is OFF and place onto pins 1 and 2.
Power on your machine for a minute. (Note: Your system will not POST).
Shutdown your machine and put the jumper back to pins 2 and 3. Your
This is a great troubleshooting
step for those of you having POST issues or no POSTing at all. Like
other troubleshooting
steps, this will not always work but usually will
depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
