SOURCE: Stiletto 10 is not reconized by My Sirius Studio
Firmware version was too old to be reconized by new version of My Sirius Studio (MSS). Put Stiletto into recovery mode, pulled the latest driver from sirius, updated, which allowed MSS to see the unit.
SOURCE: usb connection on sirius stiletto 2 to pc
You must be sure to have satellite radio turned off in order to connect to the pc. If you are using a home dock, first make sure satellite is off and then push the "Sync" button on the front of the home dock.
SOURCE: Sirius Stiletto 2 Problem
That's one of several problems my Stiletto 2 has. The only solution I've found is to "reboot" the unit. You'll have to remove the unit from the cradle, pop the back off, and remove the battery for a few seconds. Then put everything back together and power it up. It will take a minute or two, but once it reboots it should be fine.
SOURCE: Sirius stiletto 100 in demo mode
All you have to do is press and hold the display button for approx 30 sec with the unit powered on. It took mine right out of demo mode.
SOURCE: white square on sirius stiletto 2
I ran the stiletto device recovery program and it works again. You can find it on the Sirius website by searching for "stiletto device recovery". However, it does delete all of the content that you have saved on the stiletto.
