F3 error code indicates that the keypad for the control panel is bad or
has a short. This will cause the microwave to beep continuously after
the set clock message appears.
1 Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
2 Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
3 Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
4 Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
5 Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
6 Repeat Step 5 for the other membrane that is on the control board.
7 Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
8 Peel the wax backing off of the top membrane, then place it on the control board.
9 Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
10 Plug the microwave back into the power outlet and reset the clock.
Hope this helps.
SOURCE: How do i replace the keypad of GE Profile over the range microwave
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It will help you test the keypad with your meter.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you'd rather have us fix it for you, we do that for $39.95 plus parts.
DISCONNECTING THE KEYPAD
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip. (A pencil eraser is better and safer).
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: ge microwave spacemaker xl1800
F-3 means shorted touch panel pad.
In order to attempt clearing the code yourself, please follow the steps below:
SOURCE: have a ge spacemaker xl1800 - f3 error
The magnetron almost shortening , the diode sound beeping / replace magnetron.
SOURCE: F3 Message and Beeping
On a GE/Hotpoint, F3 means you have a failed keypad.
If you or someone you know might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link here on Fixya http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
[email protected]
SOURCE: ge psacemaker microwave oven no working it started
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
