Question about Toshiba Computers & Internet
I turned on my laptop (toshiba satellite L350/L350D) a notification message appeared saying initialisation process had failed. It then turned the laptop off automatically. I then turned it back on, there is a blank screen, so cant turn off computer and it has left its self on standby. How can I turn it off?
Posted by deejaydawn on
Carl W
  • 343 Answers
You can turn it off by holding the power button for a few seconds till it turns off or if that does not work remove the battery.
thanks for using FixYa
Posted on Jul 01, 2011
My L350 isn't opening the desk top, instead it says Windows failed to start a recent software/hardware may be the cause. To fix the problem insert your insterlation disc (I dont have one).
Restart the computer and after it does the POST (before Windows is suppose to start up), hit F8. Select last know good configuration or safe mode.
Nov 12, 2010 | Toshiba Satellite Pro L350-S1001X Notebook
HI , I have a Toshiba satellite L350 laptop and i
Please check the display driver is installed or not or open device manager right click on the display adapter and select Update driver and then check the issue..
Feb 02, 2010 | Toshiba Satellite Pro L350-S1001X Notebook
Toshiba L350 series laptop shows "windows failed to start" screen when booting up & goes to a completely blank screen afterwards. Tried using recovery cd & can't get C prompt to come up. Need...
Shut down the laptop, make sure that no light is lit up. Before booting it back up, press and hold the F12 button. It will lead you to boot options. Open up your DVD drive and insert Disc 1 of recovery then make sure you select the ODD or the dvd drive to boot up. This will start the recovery process.
Other models has Icons for boot options. Make sure you select the single disc option to boot the ODD.
Hope this helps.
Dec 20, 2009 | Toshiba Satellite L350-ST3701 Notebook
My bulit webcam is apperaing fuzzy and i have not a clue why. how do i fix it and what is the proper program to use it? the model of my computer is toshiba satelie L350D
Sounds like it is dirty and needs cleaning. It is new? Be sure to remove the plastic cover. If not, use a qtip with alcohol to clean it.
There is no proper program to use it. You can use it with MSN messenger, Yahoo messeger, etc. Just be sure to get the drivers installed.
Nov 26, 2009 | Toshiba Satellite L350-ST3701 Notebook
Toshiba Satellite L350 service manual
there is a website that shows step by step diss assembly, here
http://www.laptopka.com/2009/05/18/remove-parts-from-toshiba-satellite-l350-l355-laptop/comment-page-3/#comment-234251
Nov 18, 2009 | Toshiba Computers & Internet
My satellite l350d won't burn CDs
The problem is: your laptop cannot read the blank disk. The possible reason is, maybe your laptop doesn't have a burner installed to it, like Nero. You'll need to buy a burner for it, if there's some available! That's no big deal, Desktops also go through that. They just need a burner, and that's all! Hope this helped!
Jun 20, 2009 | Toshiba Satellite Pro L350-S1001X Notebook
Some files burnt to dvd will not appear as a thumbnails when
Right click the images that are not being properly displayed, click Properties, then look under the General tab. Where it says "Open with" make sure you select Windows Picture and Fax Viewer.
Jun 10, 2009 | Toshiba Satellite Pro L350-S1001X Notebook
L350-170 Logon Failure
Sounds like profile corruption or virus problem. Try restarting the machine and tapping f8 until menu appears. Go into safe mode then logon as administrator. If you can get into windows, go to control panel then user accounts. Create new user account then restart machine. Log on using new user account and copy all personal files/folders to new user account.
Apr 08, 2009 | Toshiba Satellite M45-S2652 Notebook
DVD CD writer not working will play cds says writer not connected L350/L350d laptop
Remove the case and make sure that the power cable and ribbon cable are firmly in place. I always remove and reseat the cable to ensure a good connection.
If that doesn't work, please reply back.
Jun 21, 2008 | Toshiba Computers & Internet
Open Questions:
Computers & Internet Logo
194 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
