This sounds like your card has some type of error that is causing the images not to be seen. My suggestion is that you go to your local chain pharmacy (such as Walgreens, CVS, Duane Reade) and put your memory card into their photo kiosk machine to read the pictures. Hopefully their machine will be able to read the memory card and then you can have them copy your pictures to a CD/DVD. After this is done then you would be able to reformat the card and clear the error. If the card still does not read or work then it seems you will need to look into a service that does data recovery.
Good Luck,
Paul
Have your restored all your images back
yet?
If you have not, you can try my ways to
take chances:
Plunge this camera memory card back to your computer with a card Reader and see
whether it could get the same problem.
If it can be read functionally, you'd
better copy off all your stored images and format it latter to check whether it
can still work well on your camera.
But, unfortunately, if it also gets the
same card error problem, you'd better firstly try a photo recovery freeware to restore all your needed photos back:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
This data recovery freeware has helped many
people around me retrieve their inaccessible data back from a memory card or
hard drive, including mine. So, it could be a great choice for you.
Read more detailed information of this
freeware here:
http://www.freeware-fix.blogspot.com/2013/03/memory-card-recovery.html
Note: I hope you can always back up all your needed photos on different
cards or drives all the time.
