I can't remember if reason 3 settings are setup like version 4 and 5, but you should find the audio settings under the edit / Preferences menu. In the page drop down box press Audio. Now in the Audio Card driver, select DX Primary Sound Driver. This will use the same driver that windows does. If you see one that says ASIO use that as it is lowest latency. If that doesn't work you may need a better sound card. Reason 3 does not support a lot of generic sound cards. You might also try downloading the latest driver for your sound card, I could help you locate a driver if you give me the model of your PC and / the model of your sound card.
Chris
the thing is chri when i open reason 3 the demo song is there and it works perfectly so i open a new document then the sound doesent work wats wrong
When you open a new song (blank) make sure to close the old song windows. Setup your workspace with a mixer device then add the other devices you want. You can use auto route to automatically setup the wiring needed to connect the devices together and out to your sound card.
pc model :E-system
sound card: dx primary sound driver
