Question about Microsoft Windows Vista Ultimate Edition
When copying Windows Vista install dvd to usb, error message exit: Can`t copy install.wim (CRC) data error.
Posted by khush1965 on
Chris Larocque
  • 367 Answers
Make sure your install DVD is not scratched or full of finger prints. If you have another computer try using it to copy the DVD to USB. Some dvd players read dvd's better then others. If you need to, it is not illegal to download the software off the internet as long as you use the product key that came with your copy of the software when you install it. You could download the ISO from a torrent site and extract it to USB if you needed, with programs like MagicISO.
Chris
Posted on Jul 01, 2011
Troubleshooting error codes 0x80130701
this is the answer from a Microsoft engineer:
I would also suggest using a different DVD drive, or maybe copying the installation files to a USB stick (4gb or bigger) and performing a USB install. The error 0x80070017 translates to "CRC Error" which means that the files that are being copied from the disk are not making it to the hard drive with the same structure, meaning that the "original" files on the disk are being modified/changed/corrupted while being copied to the "destination" location on your hard drive during the install.
This usually means either a bad DVD, or a read error on the DVD drive.
The easiest thing is to make a USB drive to install Window s7 (and it's WAY faster than DVD too!)
http://technet.microsoft.com/en-us/magazine/dd535816.aspx
I hope this helps. I suggest (if you have a back-up copy) to burn a new copy of your install DVD. The present one cannot be fully read by your drive. With the new copy it will work fine as long as your DVD Rom is in good order. The USB install depends on you having a good copy of the software to load on the memory stick anyway. I think that's it all covers eh ? Good Luck, Ray.
I too hope it helps
Jul 08, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to install vista from pendrive
Its very difficult to install windows vista if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows vista DVD
Step 1: Download HP USB storage format tool from here and install on your computer.
Step 2: Once you finish installation, double click on HP USB storage format tool and format your pen drive in NTFS
For this, select NTFS from File system option and Check quick format option and click on start.
While doing the format the data stored on your Pen drive will be lost. You keep a back if needed. Press YES on the warning message
Once the format finished you will get a message with the details and Click
on OK
Now insert Windows vista DVD in to DVD Drive and go to command prompt.
For that go to start -> RUN and type CMD and press enter or OK
You will see the command prompt with black back ground
Now you need to change the directory to your DVD drive where you put the windows vista DVD.
For that type G: and press enter (here I am using G because in my system DVD drive letter is G. So you need to check your DVD drive letter and type accordingly)
So the directory will change to G:>
Now type cd boot and press enter
Now the interface will be like G:boot>
Then type bootsect.exe /nt60 h: (where h is the drive letter of your pen drive)
Now you will get a successful message like below
Now you can close the command prompt and copy all the contents from the windows vista DVD to the pen drive
It will start copying now
Once it’s finished, you need to restart your pc and access the bios of your system and make first boot device as USB pen drive.
That’s it, now you can see installation starts from the USB pen drive.
on Mar 02, 2010 | Microsoft Windows Vista Ultimate Edition
Completed with errors message when creating safety drillll copy
how to recover raw drive data
How to recover "raw" drive data:
When a hard disk drive bracken or loss her partition and if you try open this drive then you got this message "Disk not formatted" .
At the times you should use any "raw" data recover software .
or
use recover "partition damage" software download.
recover everything
Nov 10, 2013 | Maxtor OneTouch 4 Mini 120GB External USB...
Xc000035a error ocurred when installing windows 7 in hp 530 laptap
suggest using a different DVD drive, or maybe copying the installation files to a USB stick (4gb or bigger) and performing a USB install.The error 0x80070017 translates to "CRC Error" which means that the files that are being copied from the disk are not making it to the hard drive with the same structure, meaning that the "original" files on the disk are being modified/changed/corrupted while being copied to the "destination" location on your hard drive during the install.
Also, run the Windows 7 Upgrade Advisor, it will scan your system and provide a report telling you if your PC can run Windows 7 and if there are any known compatibility issues with your programs or hardware.
Windows 7 Upgrade Advisor:
http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displayLang=en
If this is a digital download of Windows 7, try burning again at the lowest speed possible or download another copy of the software and try downloading again.
I hope this helps.
Sep 13, 2011 | Computers & Internet
Error: code0x80070017
When you install Windows 7 (or Vista) you may get the following message:
Error 0x80070017 Windows cannot copy files required for installation. These files may be corrupt or missing. Make sure all files required for installtion are available, and restart the installation Error code: 0x80070017
This can be displayed with error code 0x80070017 or error code 0x80070570 in Windows 7 or Vista
The cause is very simple and you can probably guess from the error code in the screenshot above. The cause is that Windows cannot verify the files.
Simple Solution
  • Burn or get a new copy of the disk (Burn at a slow Speed 2x and use a quality media like (Verbatim)
  • Or if you have a current Windows installation you can install from the hard drive or from a USB drive
Check out my article on installing Windows 7 using a USB Key USB-stick-from-windows-xp/">Install Windows 7 from USB Drive
Dec 25, 2010 | Computers & Internet
HI GOOD EVENING I AM UNABLE TO COPY MY MICROSOFT OUTLOOK 2007 PST FILE TO EXTERNAL HARD DISK. AFTER STARTING COPY FEW MINUTES LATER I FACE THE FOLLOWING PROBLUM CANNOT COPY OUTLOOK:DATA ERROR(CYCLIC...
A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
Try to copy the PST file to another file on your 'C:' drive.
If you do not see the "check", then it is the external disk-drive that has a problem.
If you do see the "check", then open Outlook, create a new folder,
and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
Sep 07, 2010 | Computers & Internet
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Cyclic redundancy error
In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear,
All of the above is true, didnt write it myself copied it from a good friends post. It is probably the data itself that is corrupted. Doesnt mean the data is gone. Try running a disk defrag, if that doesnt work try copying it to a cd/dvd and see if you get the same error. If you dont, flash your bios. This should explain your problem, if it doesnt follow up with me, email address is kustom42 at gmail.com.
Jul 14, 2009 | E-Machines eMachines Desktop PC
Cant install windows vista getting error message in installation
The only thing I can think of for an error of this kind would be faulty media. I would suggest getting ahold of another copy of the Windows Vista Install disc. Note that it matters not what Version the Install disc is, you have the Windows Key you need to use, it will install the correct version on its own.
Jun 21, 2009 | E-Machines eMachines Desktop PC
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
