Question about Canon Elura 100 Mini DV Digital Camcorder
I was importing video from this spring and noticed the audio kept cutting in and out and at times the picture would pixelate. I tried another tape and it had no audio at all. It is possible the camera was dropped at one time, so my question is Is there anyway to recover the lost audio?
  • ajames405 Jul 01, 2011
    The videos are not playing back normally in the camcorder. Previously recorded videos playback fine,but the most recent ones do not. My fear is something has broken on the camera itself, which had affected the recording. I amprobaby falsely hoping that something abbé done to recover the audio.
  • Canon Master
  • 17,970 Answers
Its possible that you have some problem in the head-record and need some cleaning job. No, if your original-master record isnt good quality video or sound are cut, no way to recovery.
Isnt a good news but is all that we can comment. Try first with time clean head.
Posted on Jul 01, 2011
  • 455 Answers
I'm sorry to know that the transferred videos are not transferring the audio along with it. I'll be glad to assist you with this.
Please make sure that the videos are playing back normally in the Camcorder. If the video and audio works normally in the Camcorder, then it can be transferred to the Computer without any issue. In that case, I suggest that you try transferring the videos using a different Software or else you can try a different Computer. This should resolve the issue.
Please let me know if you require any further assistance.
Thanks for using FixYa.
  • Eldho Shaju
    Eldho Shaju Jul 02, 2011
    Based on the information provided, it seems that the issue is in the Camcorder. As the previous tapes are playing back normally, it may also be an issue with the Recording. Try recording on a different compatible tape and check if it works. If the issue happens again, service may be required to resolve the issue, as this may be due to the recording mechanism.
    Thanks for contacting Fixya.
How to change aspect ratio?
I have found it on my remote(SAMSUNG LCD) it says picture size(psize) or go into settings and look for aspect ratio or if you have a cable box go into settings for picture size, Sometimes if theres no HD ive noticed this setting can be tricky and you always have to play with it, are you going thru your tv (what is make or model) or a vcr do u have cable box, or call the manufacturer of t.v.
Aug 12, 2013 | RCA Televison & Video
Pixelation and sound drop out
This case sounds like really dirty picture and sound heads in camera and tape kept sticking so exposure was on each part of tape too long.
Keep camera heads shiny and clean by buying camera tape cleaner.
David
Jun 01, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
Line on playback of vhs c tapes
You should play them through a different machine. Your video heads are dirty. You can get a head cleaned and this will work. It is probably not your tapes if they were kept clean.I hope this helps.
Dec 05, 2008 | Video Cameras
Pixels instea of clear picture
The problem is with the tape...Never rewind tape in the play mode for some reason it will screw it up.
And only use good tape such as...
Panasonic - MiniDV Digital Video Cassettes Model: AY-DVM80XJ
Dec 01, 2008 | Canon XL1S Mini DV Digital Camcorder
Audio jumpy on playback
these heads should be cleaned by hand, use denatured alcohol on tape cleaning sticks . never rub up and down on the video heads only sideways, be very carefull. after wardware blow the heads dry with commpressed air or wait a few hours before you stick a tape in or your tapes film will stick to the drum cylinder. if this does not work you can sometimes adjust the tape guides just little to get the audio track back on track. Larry
Sep 18, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Audio dropout
take it or ship it to video tech service. they will clear it and go from there. it may need some tension adustments in addition. The guy there is super cool.
Aug 18, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Pixelated video
Try to readjust the compression ratio. If you need more info please advice.
Mar 12, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
