Question about Apple iPod touch
When i turn my ipod on it only lights up to a blank white screen and won't do anything else
    New Friend:
  • 83 Answers
Try reseting it to factory settings plug it into the computer allow iTunes to start and it should fix the problem as long as it detects the device.
If this helped please rate
Thanks
Robert
Posted on Jul 01, 2011
How do i fix a ipod g1 with a white screen that wont show anything but white
Try letting the battery drain. Then recharge it for at least an hour. Then try to restart it.
Feb 04, 2015 | Apple iPod touch 1st Generation (8 GB) MP3...
My dell Inspiron mini won't turn on. I have
disconnectt the adapter+battery and HOLD the power button by 30 seconds. in order to eliminate any EDS, in the power. And try again.
However if the problem persist, test very well the adapter+battery and p.supply in the c.board of computer for some cold solder contact, etc God bless you
May 21, 2013 | Computers & Internet
Ipod has locked up with a blank grey screen
how old is the battery it might need to be replaced
Charge the iPod
If your iPod touch suddenly goes blank while you are using it, the culprit could be a low battery.
Prior to the screen blanking you may see a low battery indicator.
If the screen is completely blank, try plugging the iPod touch into a power source and letting it fully charge before attempting to use it again.
Restart the iPod
If you've got a white or gray screen, try to restart the iPod.
Sometimes a simple restart will solve the problem that initially caused the white or gray screen, and the iPod will work as expected once you have turned it off and on.
Reset the iPod
Resetting the iPod Touch goes a step further than just restarting, and it is a good option if you've charged the iPod and restarted and you're still seeing a blank, white or gray screen. Press on the "Sleep" and "Home" buttons simultaneously for at least ten seconds before releasing the buttons. At this point, you should see the logo or a battery icon, if the phone needs to be charged.
Restore the iPod
If nothing else has worked to remedy the malfunctioning screen on your iPod touch, try restoring the device. Connect it to your computer and open iTunes, then click on "Restore" which is found under "Summary." Be sure to back up your files when prompted, because the restore will change all of the settings on your device back to the factory default.
If even this does not work, you almost certainly have a hardware issue, and will have to take the device to an Apple store for examination and possible replacement.
hope this helps
Oct 06, 2012 | Apple iPod touch 4th Generation MP3 Player
My ipod screen is blank!! HELP!!!
First try to reset it, do this by holding down the "Menu" button and the middle button for about 7-8 seconds. If it still doesn't work, try restoring it. Plug it into your computer and open iTunes. Now select your iPod in the list to the left, then click the button that says "Restore," it`s located right under the picture of your iPod model.
Hope this helps!
Sep 03, 2009 | Apple iPod nano 3rd Generation
Screen on iPod Nano went blank (white)
press the play and pause button then on the bottom of the ipod theres a orange swich and make it turn orange...
Jan 27, 2009 | Apple iPod nano
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Try the Five R's suggested by your user's manual - you can get the manual from Apple's website if you have lost it:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
Jun 14, 2008 | Apple iPod nano 2nd Generation MP3 Player
Go throught this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Your ipod might need to be repaired, the apple service assistant is on the bottom.
Might be a loose connection or other failing component I don't think there is no quick fix for this.
If the problem is solved dont forget to rate as fixya otherwise there is no need to rate it. As there is noting else we could do about it.
May 15, 2008 | Apple iPod nano
IPOD NANO - Starts With White Screen, Stays With White Screen. Can't see Anything.
1 Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
2 Press and hold the Center and Menu buttons for at least 6 seconds, until the
Apple logo appears. this resets the ipod
Mar 16, 2008 | Apple iPod nano
Apple iPod touch Logo
66 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
