Question about Hannspree HH251H 25" LCD Monitor
My 25 was doing fine for over 6 mths but it now has ghost trails and i cannot get it to change them on any resolution..i updated my friver and also run corel grapics software..when it is still it looks great but it just a blur with movement..and yes i changed the refresh rates too....nothing works and it was making a hissing sound right before this happened ..it sounds fine now but looks like garbage...do i need to just throw this away...is 6mths a good time for an lcd to last? I did buy it on sale so maybe that was it..i dunno ..help please
Posted by rmkttk on
labcourier14
    New Friend:
  • 21 Answers
That "hissing" was most likely an electronic component frying. At 6 months it might still be under warranty- you do probably need a new set. I have been using a 32" Emerson LCD as my PC monitor for +9 years now, no problems. It is run with HDMI to the PC HDMI video card, at 1280x768 @60Hz and Windows 10.
Posted on May 05, 2017
PURE Jaguar
    New Friend:
  • 10 Answers
Its sounds like the Screen, if its only 6months old take it back to the store for either a replacement or for them to fix
AMD sempron 2600+ I have grey vertical lines on monitor have had no problems for 6 mths . i spoke to the person who set up my pc for me. they said that my graphics card is better than my monitor and...
Can you try to connect the Monitor to another computer and connect a different monitor to your computer - this might be a way to understand if the problem is in the "Monitor side" or the "Computer side - graphic card - driver". Another option is to lower the resolution and see if the problem still exists: Try to change the screen resolution to 600x800 in
->Settings->Control Panel->Display on the "Settings Tab" (the right most tab)
Apr 28, 2011 | Computers & Internet
I'm getting trails using an HDMI cord on my Vizio 32" TV. Is thsi because the HDMI is too fast for the max 720p resolution? Should I switch to component cables? I'm also using a Bluray player when it...
This problem is actually called Ghosting.
Ghosting is what happens during high action scenes or during any scenes that have low light.
There's really no way to fix it other than getting a better tv. Vizio isn't really the greatest.
The video processor on the Vizio is unable to keep up with the input and it creates ghosting.
Mar 09, 2011 | Vizio L32 32 in. LCD HDTV
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Monitor is ghosting, white trails.
You might want to try detaching the monitor and trying it on another computer unit to see if the problem still exists.  If it only occurs on your unit, then try updating the drivers on your system and see if that solves it.
Jun 30, 2010 | Samsung 225BW Monitor
My washing machine is only 6 or 7 mths old everything still working fine it just isnt spinning its still pumping water out though!
Chances are extremely good that you just have a broken coupler. These parts range from $15 - $25 on average. Were there any signs of foul play before this problem? Does your washer agitate(plastic fin in the middle rotate back and forth and wash the clothes)? Basically, if the coupler is broken, the machine with neither agitate or spin. However, you do not need a coupler to pump water out :)
I would definitely have it repaired. You should spend a little on the part + labor. Those are excellent washers and they do not make them anymore!
May 16, 2010 | Washing Machines
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
Ghosting image on canon c3220
Suggest to check the transfer unit. Especially the transfer cleaning blade..
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
Ghost and No Sound
On board sound card adapter (integrated) or separate sound card?
Which type? It is not being recognized because you failed to tell something or submit a required friver during installation and most probably it is no standard device
Mar 29, 2009 | Microsoft Windows XP Home Edition
Hannspree HH251H 25" LCD Monitor Logo
41 people viewed this question
Top Hannspree Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Karl Luedemann
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
