Question about AOMNI Corporation Magnavox 15MF605T/17 15 in. LCD TV
Trying to figure out how to convert the base to a wall mount since it appears that it is set up to do this.
Posted by curlyw2kids on
David Lee
  • 422 Answers
First get a wall mount kit. ikea sells them cheaply.
there should be 4 screw holes on the back of the screen. screws goes in there.
first drill 2 holes on the wall
mount the ikea kit using expanding bolt
then screw in the ikea kit on the monitor
just hang the monitor on the wall side.
but..... 15 inch is a bit smallish for wall mount... dont ya think?
Posted on Jul 01, 2011
  • curlyw2kids Jul 01, 2011
    Yes, it is a tad bit small - but for an RV that's the way it has to be mounted. Also, I figured it out for this particular model of TV. It comes with a mounting bracket integrated into the stand. No need to buy extra anything - you just have to know how to disassemble the stand to convert to the wall mount. So, no need for ikea - do you get a kick back from them?
  • David Lee Jul 01, 2011
    ic. then its perfect. however, i think for rv application, you should use a swivel head.
    ikea... i wish i get something from them. just that i like their solution is usually simple and elegant.
Can the base be mounted on the wall? I saw a "yes" answer on a forum, but it did not give info on how to install it to the wall. Set did not include a mount for the wall.
if the base does not have a "modern mount" set of holes in it's back then getting it go on wall is gonna be a chore , one simple trick idea that I did with one in my shop . was to obtain a simple small shelf bracket at the hardware store and mount that to wall and set phone base on that ! they cost about 75 cents a piece and if you mount them upside down (tabs up) the phone base blocks them from view .you cant even see them , a few dots of silicone caulk on them before you set phone base down there and when it dries , im sure your never gonna have a problem with it falling off , now what to do with the wires running down the wall ?????
Jul 29, 2015 | Uniden D1680-4 Dect 6.0 W / Caller Id /...
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
I need to know how to remove the bottom from my Toshiba Regza TV so that I can put it on a wall mount.
What you need to do is with the model number GOOGLE to see if you can find a service manual or even a owners manual.
Most of these sets you carefully lay the set on a padded surface face down and look at back-----should be four or more recessed holes with bolts that secure the base to the back/bottom of the set.
Most of these also you have to remove that base to get the back off which is a hint---usually no small screws but bolts.
Hope this helps you
Mar 17, 2012 | Televison & Video
How to convert bis 10 desk set to a bis 10 wall set
Western Electric produced 2 different stands for "Classic Merlin" telephone sets. You will need to locate the stand designed for wall mounting. Such stands appear on eBay from time to time. Keep in mind that Classic Merlin telephone sets were discontinued many years ago so locating the correct base might be a bit of a challange.
Apr 11, 2011 | AT&T Merlin BIS 10 Phone
I am trying to mount my LG 37" on the wall and cannot figure out how to remove the stand that came with the tv
37LG30 - loosened the 4 screws on the back of the TV but base mount wouldn't come off. Found that had to remove the screws even though already loose so that doesn't bind in the holes. Did this by making the loose screws bind in the wholes. Using twisers in the whole would have done the same thing. o
Dec 27, 2009 | LG 37LG30 37 in. LCD HDTV
Trouble mounting cantilever wall mount bracket to Sony TV
Finally figured out the correct arrangement or configuration through trial and error (and my wife's puzzle solving ability). It sure wasn't clear in the instructions, and I could not get the needed information from the website of either the manufacturer of wall mount system or TV...a little frustrating, but perseverance paid off. Given the price of the wall mount, I would think they could do a better job.
Oct 24, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Wall mounting tv. How do I get the base Off?
Are you wanting to sell the base? My base is broken and I am trying to buy one.
Jan 03, 2009 | Samsung LN-S4051D 40 in. LCD Television
Removal of connecting cords
It doesn't come out. The phone does, however, provide two large tabs in the bottom of the base that you can wrap the excess line cord around to make wall mounting possible.
Jun 25, 2008 | GE 29267GE3 Corded Phone
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
AOMNI Corporation Magnavox 15MF605T/17 15 in. LCD TV Logo
300 people viewed this question
Top AOMNI Corporation Televison & Video Experts
rhodesworks
Tom Chichester
Are you an AOMNI Corporation Televison and Video Expert? Answer questions, earn points and help others
