If a compressor is starting first check the powercable, second search for the presence of an circuit breaker button, for power reset thirth option its the pressostat-switch control all the contacts if its only buzzing by starting replace the start capacitor. if there is power on the motor wires there can Centrifugal interruptor for the startup capacitor interrupted is rare but could last its inside the induction motor some compressors could have this.
IF POWER GOING TO COMPRESSOR AND COMPRESSOR NOT COMING ON CHECK AC COMPRESSOR REFRIGERANT FOR LOW REFRIGERANT.LOW PRESSURE SIDE SHOULD BE 22 - 36 PSI HIGH PRESSURE SIDE SHOULD BE 200 - 260 PSI. NOW IF NO POWER GOING TO AC COMPRESSOR CHECK FUSE AND RELAY.IF POWER GOING TO AC COMPRESSOR AND AC COMPRESSOR NOT TURNING ON. REFRIGERANT LEVEL OKAY AC COMPRESSOR CLUTCH COULD BE OPEN.
If the compressor came on when you were testing it with a test light, it sounds like something is wrong with your ground for your compressor, and completely the circuit through your test light.
