he H6 error code means the outdoor compressor motor position detection sensor error which needs an inverter tester to check it and probably replace it…
I.e, either the reason is wire gets disconnected or a temperature sensor is faulty
In this Videocon AC manual it suggests EEPROM communication failure. I don't know if this is your model because you didn't tell us what model you have. But the error could be the same no matter which model you have.
This error is internal to the control board so the only suggestion they have is to unplug the unit for 30 seconds and then plug it in again.
If you have the equipment to solder and a microscope or magnifying headset, you just might be able to see a bad solder joint and fix it if that's the problem. Otherwise you'll have to get a replacement control board.
not cutting in
