Nokia 6300 Cellular Phone Logo
Posted on Jul 01, 2011
I cant save configuration settings gprs/mms. - Nokia 6300 Cellular Phone
5 Related Answers
Anonymous
  • 89 Answers
  • Posted on Nov 12, 2008
SOURCE: configuration settings
call your sim card service providers customer care and ask them for free configurations settings.
Anonymous
  • 7 Answers
  • Posted on Dec 09, 2008
SOURCE: GPRS and MMS Settings
call ur customer care
Anonymous
  • 1555 Answers
  • Posted on Jun 20, 2009
SOURCE: mms gprs settings
talk to your customer care they only will send you gprs and mms settings you save them to your mobile.
Anonymous
  • Posted on Sep 11, 2009
SOURCE: I9 wap/gprs & mms settings for O2
Hi i have sciphone i9+++ and having a hardtime setting up my GPRS in Globe...could somebody help me? whenever I tried to do the other suggested way., error appears GPRS is not subscribed
Anonymous
  • Posted on Feb 06, 2010
SOURCE: my nokia2630 settings for mms/gprs
i want gprs setting of nokia 2630 can you help me!!!!
It's on my Smart No. 09199634778. It received messages from Smart that I have MMS pictures. Can they be shown here?
Yes sir,to retrieve MMS data,you should activate you MMS/GPRS by configuring the settings of your network provider or Smart provider.
Here's how to Activate the your MMS/GPRS
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333′
To activate SMART MMS:
Key in "MMS ON" and send to "333′
Note :
The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
Hope this solution helps you. Thank you for visiting FixYa..
2helpful
I cant open my GPRS and i cant received and open MMS
If you want to open your gprs setting there are 2 option to open it 1st open your phone click your sim card then click the active gprs then after that they have send you configuration access then all you have to do is to save it 2nd you call your network operator then ask for manual configuration then all you have to do it write in extra paper then after you write ..set your gprs manually hope it will helps you alot
Jul 18, 2011 • Cell Phones
How to enabled MMS?
If you want to want to enable they have 2way 1 you need to click your simcard then click for the gprs on then after that you need to put your mobile brand and model then after that they send you a configuration code then all you have to do is save it 2nd option you call your network operator and tell about your gprs mms setting they have 2option for you to enabled mms gprs 1st they send you a configuration access then you save it and its done. 2nd you put manually your mms configuration.. Hope it will helps you alot
6helpful
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 • Cell Phones
1helpful
Panu ako makakapag internet sa fone??? nagtry aq kea lang may kailangan pa atang configuration... manual daw??
Ano po bang model ang gamit ninyo? maaari po kayo mag internet sa phone sa papapagitan ng wi-fi o GPRS. Kung may wi-fi po ang phone ninyo,i-on lang po ito at pwede na kayo dumiretso sa browser. kung wala namang wi-fi ang phone ninyo eh kailangang ma-activate ang GPRS ninyo upang makapag internet po kayo.
sa pag activate ng GPRS, kung GLOBE po ang gamit ninyo eh automatic na pong matatanggap ang configuration settings ng nasabing GPRS,i-save lang po ito at ang may code pong hinihingi,ipasok lang po ang 1234 at pagkatapos i-save eh pwede napo kayong mag internet,basta may load po ang sim ninyo ok na po ito.
In SMART :
Here's a quick tip on how to activate your phone's Smart MMS and Smart GPRS settings if you're with the Smart network:
Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Key in "GPRS ON" and send to "333?
Key in "MMS ON" and send to "333?
Note :
In SUN CELLULAR
Activate your GPRS
Two ways to activate your GPRS:
1. Text ACTIVATE to 2300
2. Call 200 using your Sun phone or 395-8000 via landline, and a customer service representative
will assist you
Configure your Handset
Two ways to configure your phone:
1. Text SUN GPRS to 1200.
2. Manually configure your handset : CLICK MO AKO
Sana po makatungong...
Jun 23, 2011 • Cell Phones
1helpful
2answers
How to activate the gprs of n5310 xpress musi, using my smart buddy sim
Note :
Mms setting for samsung s5230
MMS and GPRS settings was made by your service provider. Basically they will send you a setting or configuration for your MMS or GPRS settings via text message. You can call and ask them to send you a configuration message and all you have to do is save the settings.
4helpful
2answers
My 3110 wont let me send pictures
hi there,
you can follow the procedure inserted below hope it will help you to solved your problem...
any further question you can log on this site,,
http://www.yugatech.com/ringtones/tips-tricks/activating-your-smart-mms-gprs/
Here’s a quick tip on how to activate your phone’s Smart MMS and Smart GPRS settings if you’re with the Smart network:
Example: If you have a Nokia 6230, that’s “SET MMS N6230
Key in “GPRS ON” and send to “333′
Key in “MMS ON” and send to “333′
Note :
The configuration settings will be sent to your phone. You will need to select “Save All” to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
8helpful
9answers
GPRS
i dont konow how to open my gprs
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
