The Speed Control lever is linked to the Speed Link mechanism, which in turn moves the
Speed Control Assembly to allow the motor to operate at different speeds.
Get a Repair Part List from Kitchenaid.com for your particular model to see how it works.
As you select different speed setting, the Speed Link simply moves forward or backward,
thus pushing the Speed Control Assembly back and forth.
If you cannot move the Speed Control lever, means that the Speed Link is somehow bent
or out of place. Remove the Motor Housing and the End Cover and check it out.
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
